Does battery/alternator affect engine performance?
Old Nov 6, 2003 | 03:36 AM
steelymatt's Avatar
Will getting a new battery improve performance or is just for electrical purposes?
Old Nov 6, 2003 | 06:47 AM
Mick Max's Avatar
Wild at Hurt
No battery will give you more HP.
BUt----------
I think it was 03SETE who put in an Odyssey 680 for a 23 lb weight savings over stock.
Some say ea. 12 lb in weight reduction is equal to about 1 HP.
Old Nov 6, 2003 | 07:19 AM
PoLo's Avatar
2-Wheelin it...
BUt----------
4th Gen GoldenGlory
i gave him an extra yellowtop i had laying around
he said after swapping it, the car seemed much stronger, and the S/C also kicked in a lot stronger.
my belief....yeah...a weak battery will affect power.
Old Nov 6, 2003 | 07:54 AM
Mick Max's Avatar
Wild at Hurt
Other than starting, and at idle with the lights on, power is'nt coming from the battery-- it is coming from the alternator. The excess power from the alternator then goes back to the battery if it needs it to keep it charged. The battery other than at idle just acts like a big capacitor to stabilize the voltage.
Unless you have a hybred honda or Toyota, a battery should not be able to give you more HP.
Old Nov 6, 2003 | 08:54 AM
spirilis's Avatar
Yeah, the battery acts as a stabilizer for voltage. Theoretically, a stronger battery (putting out more voltage) should result in less AC ripple in the electrical system's DC output, and more stability (less AC ripple = electrical system voltage won't drop as low between wave crests from the alternator's output)... so it is conceivable that a fresh battery can improve overall performance over an old worn-out one, but I doubt the difference is that big.
More info on AC ripple in an alternator's output: http://www.eatel.net/~amptech/elecdisc/charging.htm
derekinthez
Nov 13, 2022 04:00 PM
conansriver
Nov 18, 2015 02:46 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
carid
Sep 9, 2015 05:06 AM
