Tockico VS GR2
Old Nov 8, 2003 | 09:54 AM
scopium
Tockico VS GR2
i have maxspeed and i need shocks...
which ones is better and wont give me problems
tockico or gr2
i just want a nice comfortable ride with good cornering
are the tockicos gonna crak my springs
Old Nov 8, 2003 | 10:30 AM
limsandy's Avatar
KYB GR-2.
~limsandy
Old Nov 8, 2003 | 12:42 PM
maximamaybe's Avatar
None will crack your springs. I say go Tokico Blues.
Old Nov 8, 2003 | 12:43 PM
GreekMaxima's Avatar
I heard good reviews for KYB GR-2...
Old Nov 8, 2003 | 01:05 PM
LithiuMax
I say GR2, but that is only because I own them, so it's an opinion riding heavily on bias. Unless you get responses from people who have had both, with the same springs and every other variable unchanged, you will receive biased opinions which will not really help you decide. What helped me decide was exactly what I just described: tons of opinions, mostly saying that GR2's were the better buy. In any case, good luck with the search for truth
Old Nov 8, 2003 | 01:30 PM
Maximam's Avatar
Answer in sig!
Old Nov 8, 2003 | 03:47 PM
njmaxseltd's Avatar
KYB GR2's are a firm strut
Tokico Blues are softer and will give you more of a factory like ride.
Figure out what YOU want and purchase accordingly.
Old Nov 8, 2003 | 04:46 PM
Maximam's Avatar
If you take into cosideration what njmaxseltd said, you should get the GR2s. A firmer strut controls the higher spring rate associated with the Maxspeeds.
Old Nov 8, 2003 | 05:30 PM
Triple8Sol's Avatar
I miss the .org!
I've got GR2's with my Tein springs. They seem ok, although I've never tried Tokico Blues. I got 'em after finding the same results as LithiuMax
Old Nov 9, 2003 | 12:28 PM
scopium
i want a shock that will give me a somewhat factory ride... however a little stiffer and will help the drop... is there a difference in drop with difference shock?
people are tellin me different stuff and i'm confused.. but i'm leaning more towards tockico..
anymore opinions?
Old Nov 9, 2003 | 02:00 PM
nissan5788's Avatar
I'm on Teins w/Toks..pretty satisfied with the ride even w/45 series tires.
Old Nov 9, 2003 | 04:05 PM
Maximam's Avatar
anymore opinions?
The shocks are all the same size. There is no difference in ride height with different shocks. The ride height changes with the springs. HR and Maxspeed springs will give you the closest to stock ride and about a 1.5" drop.
IMO GR2s are the way to go as far as shocks go with either the HRs or Maxspeeds.
Maxspeeds and GR2s will only put you out $380ish dollars!
Keep in mind, the bigger the drop the stiffer the ride will be.
Old Nov 9, 2003 | 04:39 PM
scopium
i got brand new maxspeeds, gr2 and tockicos for 300 bukcs new.. i just dont know which one to put on
Old Nov 10, 2003 | 02:33 AM
Lumbee1's Avatar
I am in the same situation. I would like to hear from someone who has had both (Although that will be rare since we all drive pretty much new cars). My stock struts are getting a little squishy and I think it is time to replace them. I want what everyone wants, full control without a harsh ride and unfortunately it usually boils down to one or the other. For me I would rather give up some control for a softer ride.
BTW, I have read other posts that said the Tokicos were harsher than the GR2's. Sorry to make this thread even more confusing.
Old Nov 10, 2003 | 05:04 AM
gtbigup's Avatar
[/I]
I too am trying to buy some springs/ shocks. I've been reading up on opinions for a while and still cant make a decision. Thing is I think the stock ride is pretty smooth and I'm happy with it, but that ugly ase gap has gotta go. Seems like everyone favors the H&R / GR2 combination, but I'm still confused.
Old Nov 10, 2003 | 07:40 AM
scopium
i've decided to go with tockicos after taking a ride in my friends car
Old Nov 10, 2003 | 12:33 PM
MaximaSe2002's Avatar
well i just installed the tokicos yesterday (i've been running the maxspeeds with stock struts) and so far i like them alot... the ride is a little stiffer but not bad at all the car doesn't bounce anymore either
Old Nov 10, 2003 | 01:23 PM
maximadave's Avatar
detailerdaveb@gmail.com
KYB GR-2's are the way to go
Old Nov 10, 2003 | 06:29 PM
Lumbee1's Avatar
What is the price difference between the Tokicos and GR2's?
Old Nov 12, 2003 | 10:38 AM
1TyteMAX03's Avatar
I got TEINs waiting and KYB-GR2s on the way.. I'm hoping the ride is still comfortable!
Old Nov 12, 2003 | 02:45 PM
PhxBlue's Avatar
MK3 Supra and Focus ST
I have almost a 2" drop with Sprints and Tokico's on a 235-40-18 tire. My ride is sporty and firm in the corners but at the same time is not real harsh on the bumps (unless they are big bumps). I have not a single complaint about my Tokicos...
Old Nov 12, 2003 | 02:48 PM
PhxBlue's Avatar
Originally Posted by Maximam
Answer in sig!
Your car looks really cool in your sig.
Old Nov 17, 2003 | 06:37 PM
kevinsean23's Avatar
So how about the possibility of..
I was wondering if I got the Gr-2's would they compensate for taking the rear suspension bar off? I would like to if the rear end waggling is compensated for by the shocks. Wishful thinking?
Old Nov 18, 2003 | 07:29 AM
scxe's Avatar
do the sprints drop evenly?
Old Nov 18, 2003 | 08:53 AM
Lumbee1's Avatar
Sprints are rough riding springs.
Look at Maxspeeds, Teins, H&R's. If you want sporty, Progress and Eibachs.
For those with aftermarket struts, have you had 3 people across the backseat and driven on bumpy roads? I just want to make sure my stock struts are dead before I go buy new ones. Christmas is coming up and I have already dropped a ton of cash on everyone else.
Old Nov 18, 2003 | 11:02 AM
1TyteMAX03's Avatar
I was advised by other members that you should replace the stock struts if you lower your car due to that stock struts can't handle the aftermarket spring rate.
BkGreen97
Apr 2, 2016 05:47 AM
Entropy
22
Dec 2, 2002 06:30 AM
maximarolla
Jun 18, 2002 12:54 AM
nstymax93
Oct 31, 2001 10:01 AM
