Car Died Need Help
Old Nov 9, 2003 | 07:57 AM
Tim01MaxSE's Avatar
Car Died Need Help
Hey guys my car craped out on me last night and i have no clue whats wrong....i have a franken car intake on for a week if that will help but heres what happend...i came onto the highway grabed 2nd(manual) then hit rev limiter for 3rd cause of tire spinning then the car just died..just shut off...i coasted down the hill to a parking lot and tried starting it...it ran for a second and when i touched the gas it died....dont know what happend..but when i unpluged the maf it ran but ran sh.tty.. and for some reason it was hittin a rev limiter at 2500....non of this makes any sense to me can anyone help thanks Tim
Old Nov 9, 2003 | 08:53 AM
filtor1's Avatar
Re-install stock intake. Take it to Nissan for a MAF relacement. If it is not under warranty, someone here can get you the sensor portion instead of havinh to buy the entire MAF assembly.
Old Nov 9, 2003 | 09:47 AM
UMD_MaxSE's Avatar
Got Bent?
dead MAF.....
Old Nov 9, 2003 | 10:04 AM
PoLo's Avatar
2-Wheelin it...
definitely a bad maf. no question about that.
2 choices.....setup stock intake and go in, play dumb, and get the maf replaced under warranty.
if you're not under warranty
call Dave Burnette (you can't say DaveB anymore because there's another DaveB in parts department) at south shore nissan (888-254-6060) and tell him you got a messed up maf *SENSOR* from your intake. he'll know exactly what you need. cost is $75+shipping. if you go to your dealer, they'll say you need the whole maf piece which is $480. we've already pinpointed it to the sensor only.
good luck...and good idea on disconnecting maf...that's exactly what you should have done. it keeps the car at least running instead of shutting off.
*tip*- another way to prove if you're maf has gone bad is to turn on the car, and blow into the maf (obviously you remove the intake) this fluxuation of air will cause the car to dip in rpm's, if done hard enough it will shut off. here's the trick. if that DOES happen, then your maf is fine. it's supposed to work like that...think about it. a lot of air at idle will miscalculate the air/fuel mixture and cause it to dip in rpm's. now, if you blow into the maf and nothing happens, that's just another way of proving you have a messed up maf.
edit- tip given to me by my friend, master tech and koeppel nissan in queens, NY. it's how they frequently test for maf's, because you blowing into the maf are acting like an intake yourself, and simply proving whether the maf is reading the air intake values correctly.
Old Nov 9, 2003 | 04:05 PM
Tim01MaxSE's Avatar
how do i know for sure if its under warrenty...o have 36,011 miles on it..in the warrenty book it says the maf is covered up to 80,000 miles ???
Old Nov 9, 2003 | 04:11 PM
PoLo's Avatar
2-Wheelin it...
well if it says 80k, you bring that in as well and show it to them.
i guess if you played dumb, they may pull the "past 36k so your **** outta luck"
but then again, if you play the smart one, tell them you tested it and it seems the maf is bad. explain the symptoms, etc.... and then they should continue from there and then do the warranty replacement. have the paper that says the maf is a 80k warranty piece, incase they try to pull something on you, forcing you to pay...if worse comes to worse, know that you can always do it yourself, so no matter what, do not let them fix it if it's not covered under warranty. they'll charge you up the a$$.
hope this helps.
Old Nov 10, 2003 | 04:28 AM
Tim01MaxSE's Avatar
ok thanks guys.....so i take it i should NOT put my frankencar back on????
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
