Stillen Rear Sway Bar Placement?
Old Nov 15, 2003 | 10:22 PM
FrankTheBunny's Avatar
For those of you with the Stillen RSB, where did you place your bar in relation to the axle?
I wanted to keep my axle free for my jack, so I tried putting the rsb just behind it, and I thought it would clear the multi-link but it's hitting on even small bumps.
So I'm going to move it and I'm trying to figure out where the best place would be to put it. In front of the axle is what I'm thinking.
It's more effective closer to the front of the car, right? So I wouldn't want it behind the multilink, correct? Or should I put it right under the axle and jack the car up some other way? If so, where?
And yes, I searched, but none of the 63 results went into the detail I'm looking for.
Thanks!
Old Nov 16, 2003 | 12:21 AM
jonbth's Avatar
Did it come with instructions? I don't remember where I mounted my bar but I followed the instructions. I'll look when I get a chance and let you know.
Old Nov 16, 2003 | 03:01 AM
maximilion's Avatar
I got my swaybar from another org member and I was wondering the same thing too. I have mine directly under (or even touching) the rear suspension.
Old Nov 16, 2003 | 07:10 AM
.45's Avatar
.45
Originally Posted by FrankTheBunny
For those of you with the Stillen RSB, where did you place your bar in relation to the axel?
Here's mine post-install:
Old Nov 16, 2003 | 07:24 AM
Originally Posted by .45
Here's mine post-install...
So is that directly under the rear axle? What do you use for jacking it then?
Old Nov 17, 2003 | 06:25 AM
Todds_max's Avatar
I used the outer-most holes, 5 to choose from. The bar sits very snuggly directly under the axle. Had to get creative with the abs wire bracket
Old Nov 17, 2003 | 11:52 AM
.45's Avatar
.45
Yes, give or take a .25" if I had to estimate. The work was scheduled/performed on a lift by my long-term mechanic (no credit here) while I had the car in for other service. While I did not turn-the-wrenches I did the test drives and it took two "re-adjustments" to ensure proper fit with no unusual bumps, sounds, etc. I put ~50 miles on the car and had the unit re-tourqued same day. Put another week of city and highway driving on and went back for one more re-torque. Been solid since day 1 and money very well-spent.
Old Nov 17, 2003 | 12:19 PM
Y2KSESteve's Avatar
Mine went directly in the middle of the rear suspension bar. Use the 3rd and 5th holes for installati9on.
Old Nov 17, 2003 | 05:32 PM
I just moved it under the axle. The only reason I hadn't done that from the beginning was I didn't know where to put the jack. I took Todds' suggestion and just jacked it up one side at a time.
Works great now, WOW what a difference!
Thanks for the help guys.
Old Nov 17, 2003 | 05:33 PM
Originally Posted by Todds_max
...Had to get creative with the abs wire bracket
Me too. I just took that whole little bracket off and zip-tied the abs to the e-brake line.
Old Nov 18, 2003 | 03:45 AM
SEmy2K2go's Avatar
Go BUCKS!!!
I have the progress RSB and their directions actually say to remove the ABS bracket. I have my bar directly under the axle.
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
doctorpullit
Sep 10, 2015 06:33 PM
