Question: Should revs drop when put into D or R?
Old Nov 21, 2003 | 12:09 PM
Modeflip's Avatar
My 00 Maxima is my first car so im not really sure if this is usual but when I turn my car on in park the revs stay at about 1100-1300 and when I put the transmission into D or R it goes down to 800. Is this supposed to happen? Kinda a stupid question but it just seemed weird...
Old Nov 21, 2003 | 12:11 PM
ToYLeT902's Avatar
JET Speed Lab
Yes that happens, especially if you just started your car in the morning to warm it up.
Old Nov 21, 2003 | 12:17 PM
desperado_45's Avatar
Same thing happens to me.
Old Nov 21, 2003 | 12:57 PM
kcowden's Avatar
Give it a few minutes to warm up if possible. It's not good to shift your car into gear while the RPM'S are that high.
Old Nov 21, 2003 | 12:59 PM
Modeflip's Avatar
Thats the thing, I do let it warm up, its usually starts at 1300-1400 in P and I let it go down to 1100-1200 but it doesnt go down anymore until i start to drive it around and then put in back in park.
How long do you usually let cars warm up? I usually do 3-4 minutes
Old Nov 21, 2003 | 01:02 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i let mine idle for about a minute and keep the revs under 3k til the temp gauge has come up and sustained for a little while.
Old Nov 21, 2003 | 01:04 PM
kcowden's Avatar
3-4 minutes should be fine, unless it's really cold, the rpm's shoud be down after that amount of time. After you drive it for a while what are the rpm's if you go to P or N?
Old Nov 21, 2003 | 01:06 PM
Modeflip's Avatar
After I drive for a while its about 900-1000 in D
Old Nov 21, 2003 | 01:11 PM
VMaximus02's Avatar
Your idle is a little too high. It should be in the 650-700 rmp range once the engine is warmed up.
Old Nov 21, 2003 | 01:14 PM
kcowden's Avatar
That seems high, I have an 03 auto and it idles in gear around 4-5k. Mabye some BG44 fuel injector cleaner, cleaning the throttle body, if those don't work I'd take it in to have it checked. Good luck
Old Nov 21, 2003 | 01:39 PM
VMaximus02's Avatar
Your idle is too low...Are you sure you read the needle correctly?
Old Nov 21, 2003 | 01:44 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
Eh?? 4-5K (as in thousand idle!!) ?!?! That can't be good...
I'm sure you meant to say 4-5 "hundred" RPM is where it idles...
Old Nov 21, 2003 | 02:24 PM
GreekMaxima's Avatar
This happen when your car is cold... just give it a few minutes to warm up!... it is normal dont worry about it!
Old Nov 21, 2003 | 06:32 PM
Modeflip's Avatar
Yeah, you guys are right, after I just got home the Idle was pretty much the same in P and D, around 7-800
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
nbstriker10
Sep 4, 2015 04:26 PM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
