02' PVC valve location?
02' PCV valve location?
Can someone please post a picture of its location? I am in need to change it soon...got the part here but couldn't find it! This thread had been posted before but no direction or picture of it. Again, this is for the 02'-03' Maxima, not the VQ3.0 motor. Thanks ahead.
*title corrected*
*title corrected*
Originally Posted by charliekilo3
As soon as I can get a good shot of it, I will post it for you.
The one that I got was a plastic pull out type, not the metal screw one. That was why I had such a hard time locating it in the first place!
Thanks for the picture! I've just check the part number on the PCV valve that I got from Courtesy-Nissan. Apparently they had sent me the wrong one.
yes, that's the one. I called them earlier this morning and they're going to shipped me the new one.
You're welcome. I hate it when I get the wrong part. Some parts guys try to blow smoke by telling you "it crosses over to this part number." Some of them are so fullofsh*t.
Did I miss something? Where is the picture?
Yes, you missed it. I had to email it to VMaximus02 because I don't have any webhosting. My Spyblocker software won't load the website. I can email it to you if you need it.
Vincent_Dunn@baxter.com
Yes, if you send it to me I will host it on my site for all the masses.
HotShot2002@nc.rr.com
Got it. So the hose is clamped to the PCV, right? Your car looks Baby Blue in that pic.
Good looking out with the pic. This should be an easy job, right???
Originally Posted by maximadave
how can you tell if you need to replace it or not? I have 48K miles and have never replaced it.
Per the Nissan service manual, "with engine running at idle, remove PCV valve from rocker cover. A properly working valve makes a hissing noise as air passes through it. A strong vacuum should be felt immediatley when a finger is placed over the valve inlet."
You have to remove it to check it. The valve should suck vacuum from the intake manifold when the engine is idling. When you shake the valve in your hand, it should have a rattle sound from the inside of the valve. That would indicate it is free to work and not clogged up or stuck.
I'm about to order my PCV valve from Courtesy NIssan. What is the correct part #?? Their website says the 2K2 uses the 11810-8J101 ...is this correct???
Any idea if that is correct? I see my part number is off by one number from what others have said in this thread. My part number ends in 2 versus 1.
THANKS
schernov@hotmail.com picture please!
Originally Posted by schernov
picture please!
Thanks for the photo.
My dealer supposed to replace the PCV valve per 30K service, but they didn't (did not show part on receipt) so when I asked about it, they gave me a run around saying that it's actually directly beneath the intake manifold and that it would cost me additional 4 hrs ($70/hr x 4) to get that replaced.
What a bunch of scammers.
tseng1023
10-15-2015 08:30 AM
hayne
10-05-2015 11:53 AM
DC_Juggernaut
09-28-2015 04:07 PM
