Maxima pulls to the left
Old Apr 11, 2005 | 04:47 PM
2KmaximaSE's Avatar
I hit the gas and the car pulls to the left??? I thought maybe it needs an alignment but the guy at the shop said it could be something with the tire? If I am driving down the highway and I let off the gas and the stearing wheel I am in the left lane quickly. Anyone have this happen to them before? I also had a new tire put on the left side about three months after I had one put on the right side but they both have the same wear. Anyone???
Old Apr 11, 2005 | 05:22 PM
irish44j's Avatar
retired moderator
are both tires the same?
some tires have what's known as "radial pull" which makes them pull to one side.
also, there's torque steer, but that's when accellerating
Old Apr 11, 2005 | 05:48 PM
XGaSpAcHo
mine pulled to the left a few months ago after i got it back from the dealership. sears said my allignment was pefect. what happened was the retards put a lot more air in one tire than the other. the pressure was off by about 5psi. once i let some air out the car drove fine.
Old Apr 11, 2005 | 10:39 PM
maxfive-O's Avatar
when did this start happening? That's usually a clue to the problem.
Old Apr 12, 2005 | 04:05 AM
pimpinmax's Avatar
doealer told me its torque steer
Old Apr 12, 2005 | 04:29 AM
Cutler's Avatar
Trade it in.....
Old Apr 12, 2005 | 04:31 AM
Cutler's Avatar
JK, it's prolly alignment or tire pressure issues. But as Irish said, if you have directional tires, that can also do it as well....
Old Apr 12, 2005 | 06:33 AM
MacAlert's Avatar
Mine has been drifting both left and right. It started after the blizzard we had a couple of months ago.
Old Apr 12, 2005 | 07:53 AM
Ammi's Avatar
350 Detroit Muscle
last time I had that problem was went I had a slightly bent tie rod.
Old Apr 12, 2005 | 10:09 AM
00Max00's Avatar
slightly pull to the right is usual due to the curve of the road surface. but don't know why its pull to the left if 1. tires are inflated properly 2. suspension has no problem 3. alignment is OK. My best guess is to check if there's something wrong with the suspension.
Old Apr 12, 2005 | 10:44 AM
Maximax2's Avatar
5th gens are VERY sensitive to tire pressure.
Old Apr 12, 2005 | 03:05 PM
BM_00's Avatar
Bullseye. A few PSI can affect your steering pull. 1st check to make sure your tires are pressurized accordingly and the same amount. Then if it still pulls troubleshoot other areas.
Old Apr 15, 2005 | 04:41 PM
2KmaximaSE's Avatar
This is what the problem was. I can't believe how much it did pull to the left just becasue of tire pressure...
Old Apr 18, 2005 | 10:40 AM
bitar_19's Avatar
Check your air pressure thats what was wrong with mine
Old Apr 18, 2005 | 10:45 AM
XGaSpAcHo
you're about three days too late dude.
Old Apr 18, 2005 | 04:40 PM
2000 Maximus's Avatar
HAHA, this is becoming a pretty funne thread.
Yea as said tire pressure is very sensative on our cars but we all know that by now.
LOL
trasmadean
Feb 1, 2017 08:20 PM
acw
Aug 13, 2015 12:50 AM
Flores94
Aug 11, 2015 12:53 PM
kirkhilles
Aug 8, 2015 10:53 AM
