Battery Question...
Old Nov 25, 2003 | 11:27 PM
ToYLeT902's Avatar
JET Speed Lab
Battery Question...
So my battery died out on me about an hour ago, should i just get a replacement or are you supposed to fill it up with water or something?
Old Nov 25, 2003 | 11:29 PM
krmaxima's Avatar
why did it die???? did you leave your lights on or did it just die because its old??? if so time for a yellow top.
Old Nov 25, 2003 | 11:36 PM
ToYLeT902's Avatar
JET Speed Lab
i didnt leave anything on, i just hopped in to start it, heard click click, and then the car had no more power. The battery is like 2 1/2yrs old?
Old Nov 25, 2003 | 11:43 PM
MyownNismo's Avatar
Future Camaro SS owner
Get a yellow top. I need to get one for mine. I had one in my other car and i could jump start cars without my car even being on.
Old Nov 26, 2003 | 12:21 PM
2k1seae's Avatar
I just had my Max serviced about a month ago. Everything was okay except the battery wasn't putting out enough amps (I don't know how much longer it would have lasted). I had no idea it was going bad. Since it was still under warranty, I had them replace it. Pro rated, it came to $25 (good for another 5 yrs). This was orig battery - 2 1/2 yrs old.
Old Nov 26, 2003 | 12:24 PM
limsandy's Avatar
Ooo, ****e. If most Nissan batteries die out in 2.5 years, then I'll be replacing mine soon. But I know what I am going to get already. Optima Yellow Top.
~limsandy
Old Nov 26, 2003 | 12:51 PM
soundmike's Avatar
Very sound, Mike
Mine died in the same period of time - i got a pro-rata discount for a replacement but i decided to forego it.
I got a Red top instead. 300 more CCA than the OEM - good enough for me
PoLo's Avatar
2-Wheelin it...
get a red top. you cleaned out your system. that car is your daily driver. the red top is more of a starting battery whereas the yelloe top is more deep cycle. and yes are supposed to check the water level. take that black cover off and look at the holes. i believe you should see a water level there. if it's that low, then damn you need to add some water.
i believe it has to be DISTILLED water as well. checkt he manual to be sure.
Old Nov 26, 2003 | 03:41 PM
ToYLeT902's Avatar
JET Speed Lab
Yep, i filled it up with distilled water, and now my battery is like new, woohoo... free fix!
Old Nov 26, 2003 | 03:59 PM
limsandy's Avatar
Dead battery revived !!!
~limsandy
Old Nov 26, 2003 | 04:36 PM
trey
Hey why don't they make are batteries maintenence free? I'm thinking because it would cost more.
Old Nov 26, 2003 | 05:06 PM
soundmike's Avatar
Very sound, Mike
Optima's are as maintenance-free as it gets. There are other battery makers out there that makes similar one's as well.
Old Nov 26, 2003 | 05:16 PM
Bluesbrekr's Avatar
Doctorate in Detailing
They must not make em like they used to. Batteries used to last about 5 years, providing you kept the water level up.
I got a Red Top and put my 6 month old factory battery in my wife's Camry cause hers needed to be replaced.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
