2k2, 2k3 bose question
Old Nov 27, 2003 | 10:51 AM
serin's Avatar
ok, the audio forum is a ghost town, so i'll post here.
i recently tried out a 2k2 bose w/6cd in-dash in my 2k. (works with my stock harnesses btw) but when i put the volume up past 18, the amp seems to cut out and all i get is progressively louder static. the music volume doesn't seem to get any louder, just static. same with cds and radio. it's such that i can't hear a thing at highway speeds.
anyone else have that problem? solutions??
Old Nov 27, 2003 | 11:49 AM
Igor911's Avatar
I can sell you the bose amp from my 2k2...
Old Nov 27, 2003 | 11:54 AM
MaxRod33's Avatar
Hey Igor, what type of bulbs do you have in your fogs and clearance lights (next to the headlights)? I put in Polargs in the clearance lights and compared to the HID's they seem yellow still. Thanks man.
Old Nov 27, 2003 | 11:58 AM
Igor911's Avatar
Either PIAA or Polarg, can't remember
Old Nov 27, 2003 | 06:25 PM
RichK's Avatar
Do you have a Bose system in your 2000? The Bose radios are not powered radios. They are pre amp radios and require amps to work correctly.
Old Nov 28, 2003 | 09:46 AM
serin's Avatar
omg i feel dumb. after all the reading i did on this thing, i somehow missed that. so, if i get a 4 channel amp all's good??? how does the stock bose amp install? does it i go in remotely and then have wiring harnesses come all the way back to the h/u or does it mount somewhere inside the center stack??
igor, weren't you the one i spoke to a while back regarding the stillen cd rotors?? what'd you finally decide to do about that?? cuz one of my rears is scored too. but no problems so far.
and how much for the stock amp? got stock harnesses???
thanks guys.
Old Nov 28, 2003 | 09:54 AM
serin's Avatar
o yeah, so the speaker outs on the h/u are actually pre-outs right? what voltage are they?
Old Nov 28, 2003 | 10:51 AM
2k3TitaniumSe's Avatar
yeah bose seem to have problems with amps like in my 93
Old Nov 28, 2003 | 07:25 PM
RichK's Avatar
The Bose amp mounts under the rear deck on the passenger side. The outputs from the radio go to the amp, then all speakers hook up to the amp. The amp also has a "summed" non fading output for the subwoofer. You can do it, but it's gonna take some extra parts. If you are car stereo savy, it won't be that bad. If you aren't, find a good stereo shop. I think the Bose head units are about 5V out. But Bose radios use DC Offset on their outputs therefore making them tricky to add aftermarket amps to.
Old Nov 29, 2003 | 11:50 AM
serin's Avatar
5v eh? will an amp with 4v pre-ins work? and what's dc offset?
specifically, i was looking to use the Alpine MRP-F240
http://www.crutchfield.com/cgi-bin/S...=0&cc=01&avf=N
and i thought it was advised not to mount amp under the rear decks cuz the heat would rise.
Old Nov 29, 2003 | 01:24 PM
RichK's Avatar
That amp should be fine. You can mount it under a front seat. I was just saying where Nissan put the Bose amp. As far as interfacing it with the Bose radio, you will need an adapter. PAC and Soundgate both make adapters that will work. The people at Cruthfeild will know which to send you when you buy the amp.
Old Nov 29, 2003 | 01:43 PM
Igor911's Avatar
If anyone wants to buy the bose amp from a 2002-2003 PM me....
Old Nov 30, 2003 | 10:55 AM
serin's Avatar
well, the reason i ask about the placement is that if my car's prewired for it, wouldn't i be limited to the trunk? and the adapters you're talking about are for interfacing with the bose h/u right? cuz the guy at crutchfield said they had em for the non-bose h/u but not the bose h/u.. anyhow, i can try PAC
Old Nov 30, 2003 | 02:43 PM
RichK's Avatar
The car isn't going to be prewired for the Bose amp. What you are going to need is an adapter that will take the Bose radio outputs and make them a true pre-amp output. A number of companies make them. You are going to have to cut the speaker wires behind the radio at the plug. The adapter will be wired to the radio side of the cut wires. The adapter will have 4 pre out plugs on it. The other side of the cut wires(car side) will be your 4 speakers. It really isn't that bad, but I have alot of experience in car sound so I guess it seems easy to me. You can also try local stereo shops or a local Circuit City for the adapters. Chances are that they will have what you need. I know the Circuit City by me carries the adapter you will need. I don't have a part number though. Let me know if I can help out. I'll try the best that I can here.
Old Nov 30, 2003 | 04:15 PM
serin's Avatar
ok. i know exactly what you mean. i was thinking that same thing. i was just confused with all the posts and pms about pre-wiring and existing harnesses. so it seems that all i need to do then is get the adapters to make true pre-outs then wire normally to an amp then run speaker wires back to behind the center stack where the stock speaker wire are.
right??
Old Dec 1, 2003 | 04:17 PM
RichK's Avatar
You got it. Again, let me know if I can help. Trading info in posts can get confusing sometimes.
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
popdedop
Sep 11, 2015 11:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
