Sterring wheel shake?
Old Nov 28, 2003 | 05:57 PM
edaskew's Avatar
I get a steering wheel shake under moderate braking at 60 + mph....
I'm thinking warped rotors maybe?
Any thoughts?
Thanks ed
Old Nov 28, 2003 | 06:05 PM
Zero Deuce SE's Avatar
I'm thinking warp rotors maybe?
Any thoughts?
Thanks ed
I would only think about warped rotors if the brake pedal pulsates while the braking and steering wheel shaking occurs.
Old Nov 28, 2003 | 06:24 PM
bobcat's Avatar
exact same thing happend to me.. brakes are warped. If you're below 36k and haven't had your rotars turned yet they should do it under warranty (they did mine)
Old Nov 28, 2003 | 06:39 PM
edaskew's Avatar
Though so.. Its kind of unsettling,,,,,
Old Nov 28, 2003 | 07:35 PM
irish44j's Avatar
retired moderator
ON a similar note....if I get some Brembo blanks...are they pretty much bolt-on (i can do it at home with minimal effort) or will I need to take it to a shop to install...also anyhone recommend just getting fronts or should I get all 4?
Old Nov 28, 2003 | 08:22 PM
RichK's Avatar
It's not that hard to put the rotors on. You just have to remove the caliper and pull the rotor off. I'd strongly reccomend new pads as well.
Old Nov 28, 2003 | 08:48 PM
edaskew's Avatar
Got a part no or link?
Old Nov 29, 2003 | 02:08 AM
cyclecrazy55's Avatar
Most likely its the rotors warping as you've already been told. But I had shaking even when I didn't brake. Found out that when my wheels were rotated, the tech didn't torque the wheels equally. Each nut has to be torqued the same. I forgot what the torque spec is. Hopefully someone will chime in. good luck.
Any thoughts?
Thanks ed
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
