people with 02-03 maxima step in
All I can say is that my 03 or 350 donot idle no where near as smooth as my old 01 and 97. The Max idles in drive at 700 rpm when warm and in park its at 750. Since day one I can feel way more vibration in the wheel with the 3.5's vs the 3.0's, when Nissan bored it out alot of the smoothness went away IMO
Originally Posted by 2k2wannabe
about 700, and the needle doesn't move until I tap the gas.
Originally Posted by jaco
mine's between 625-675
2k2PhatMax, you'll need to use colsult II to adjust idle
Originally Posted by PoLo
that's why i have a rough idle. after i put on the injen, cattman y, and greddy, my idle dropped to under 500. it's not bad, but i'm always gonna feel a rough idle. and yeah, only a consult II can adjust it.
thast weird i have no intake or greddy or cattman y YET but my idle seems to be under 500 maybe closer to 300 or 200 to me
-J
Originally Posted by limsandy
On a cold morning, it idles at 1200 rpm. After 15 minutes, it drops to 700. Both at park.
~limsandy
~limsandy
will
Originally Posted by WILLSE
interesting..... my car does the same ****. doesnt take 15min to warm up maybe 3-5min when the temp is in the 30s. i start it up and the needle sits around 1200-1400rpms. the rpms dont go down all the sudden but creep slowly till the normal 650-750 idle sometimes ~450 when the A/C is off. im wondering if i might have some issues!
will
will
i want a new motor. i could have done a motor swap almost 2 times if i wouldnt have bought those headers. for some strange reason they dont work on my car.
i have almost 60k and drive pretty hard. new motors have been purchased for ~800. wouldnt be bad to have a extra engine and add some goodies before i drop it. just thinking.....
will
i have almost 60k and drive pretty hard. new motors have been purchased for ~800. wouldnt be bad to have a extra engine and add some goodies before i drop it. just thinking..... will
Originally Posted by MONTE 01&97 SE
Blah Blah but the truth hurts this is coming from a person that has mulitple Maximas and Z's
you guys who are saying it takes 15 minutes for your engine idle to go from 1200 to 700-ish... are you letting it run for 15 just sitting there, or do you warm it up like you're supposed to?
steps to properly warm up your non-snow-covered car...
1. open door
2. sit
3. close door
4. start car
5. fasten seat belt
6. adjust radio
7. DRIVE SLOWLY. After approx 1-2 miles the engine will be "warm".
if your car has snow on it you can start it and scrap/clean then drive.
after i put my UDP on... if i let my car idle it drops to around 600 give or take ... and its real rough....the SES light comes on too... but after a few starts and me not letting it idle low... it goes off... go figure...
but my idle is low sometimes
your opinion...
1. open door
2. sit
3. close door
4. start car
5. fasten seat belt
6. adjust radio
1. open door
2. sit
3. close door
4. start car
5. fasten seat belt
6. adjust radio
I don't know about that. I usually let the car warms up for about 3 minutes and then go slow before entering the highway.
~limsandy
~limsandy
~limsandy
letting the car sit for 3 minutes does nothing but waste 2:45 seconds worth of gas. Everything has started moving after the first 15 seconds or so and you get ZERO mpg while your car is sitting idle.
it won't hurt your car to sit for 3 minutes, but it won't help, either.
it's been shown time and time again... proper way to warm up a car is start it, let it sit for approx. 15 seconds, then drive lightly for the first mile or two.
Originally Posted by BiggD23
Have you read your owner's manual? It says to always let the car idle for AT LEAST 30 seconds before driving off. I tend to agree with you that idling for more than a minute is useless because the car warms up more efficiently while being driven slowly, but 15 seconds isn't enough time.
long live the MAX
Lakersallday24
Nov 7, 2024 07:31 PM
criminalslang810
Aug 16, 2015 08:12 AM
