Click Click Click noise when engine is shut off.
Old Dec 3, 2003 | 03:26 AM
Matto357's Avatar
So, whenever I shut the engine off in my 2k Max with 62k on it, I hear a "click click click" from the engine compartment. I tried to pinpoint the location and as far as I can tell it's coming from the engine on the right side. To the left of the stock airbox.
Any ideas? I'm thinking perhaps an engine mount, or is this normal? It does it every time the car is shut off.
Old Dec 3, 2003 | 03:51 AM
SkoorbMax's Avatar
I've noticed, with the hood up, that if I have the car OFF and I turn the key until all of the dashboard lights come on (one click short of starting the engine), then turn everything off and take the key back out a few seconds later there is a clicking from my throttle body location. Nissan says this is perfectly normal and is a solenoid or something. So, it does it for me whether the car was just turned off, or even if the key was simply taken out (as long as it was turned all the way one click short of actually starting the car).
Old Dec 3, 2003 | 05:04 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
dont ask why, but its the noise that the electronically controlled engine mounts make.
Old Dec 4, 2003 | 03:09 AM
KCMichaelM's Avatar
Seconded... This is correct...
Old Dec 5, 2003 | 08:03 PM
Mick Max's Avatar
Wild at Hurt
Which models of max have the electric motor mounts? SE's too?
If so I want to put inline fuses in mine. Guys have had motor mounts short out and burn down their ECU's
Old Dec 5, 2003 | 09:26 PM
Bulldawg's Avatar
Ummmmm.....It isn't the electronic engine mounts at all. The noise is your throttle body butterfly closing it self and then chekcing its position. If you have ever reset your ECU using the Technosquare instructions, when you re-learn your throttle position sensor you will hear this same noise. The car is just making sure everything is in place.
Old Dec 5, 2003 | 09:55 PM
WILLSE's Avatar
this is correct!
will
Old Dec 6, 2003 | 11:22 AM
KCMichaelM's Avatar
--Which models of max have the electric motor mounts? SE's too?
I believe only GLE autos have the mounts...
--Ummmmm.....It isn't the electronic engine mounts at all.
Wierd!! I was told that by a Nissan tech... I stand corrected then.
Old Dec 6, 2003 | 12:54 PM
sloppymax's Avatar
so how about for 2k & 2k1 that dont have drive by wire? the ecu in those years cannot be reset in this manner. the noise that i hear can be right from the mount below the location of the intake air box. ive been around plenty of 2k2 & k3 have not displayed the same noise i am talking about. im pretty sure since the original poster has a 2k that this the same noise i am talking about. all models of autos have the same mounts as other autos. the mounts in the manual are different but are the same in all manuals.
Old Dec 6, 2003 | 09:27 PM
WILLSE's Avatar
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
thats the culprit.
will
Old Dec 8, 2003 | 10:07 AM
Thaniel's Avatar
Auto's have the electronically controlled engine mounts.
Manual trans do not.
The wiring diagram I have for the 2000 shows a 15A fusible link (left side of engine compt) already.
Old Dec 8, 2003 | 10:12 AM
Thaniel's Avatar
thats the culprit.
will
On a 2000 the only thing that's gonna make the Throttle valve move is the cable that connects it to the gas pedal
captchaos
Mar 15, 2016 12:18 PM
Maxima30
Sep 7, 2015 06:13 PM
maxfever1987
Sep 6, 2015 06:20 PM
jfl330
Sep 4, 2015 01:44 PM
