Noise from A/c vents
Old Dec 4, 2003 | 01:15 PM
arathitr's Avatar
I get a hissing noise from the A/C vents of my 2k1 maxima when I turn on the heat . I called the mechanic , he told me that it could be some object stuck in the vent and that they have to clean the vents and would cost me $100 . Is it easy to do it on my own ?
Old Dec 4, 2003 | 01:22 PM
-Red-'s Avatar
Does the noise go away when you go from heat to cool? Does the noise level increase when you turn the AC up?
Never had the experience with my Max, but by 97 Mailbu was notorious for sucking leaves into the blower fan, but it would usually come out one of the vents after a while.
Old Dec 4, 2003 | 01:29 PM
Playero's Avatar
Sanduguero
i got the same problem but is a *&^*&#^ neon light that i stuck in the vents.....
arathitr's Avatar
Yes, the noise level does increase when i turn it up. I only hope it is a leaf which can be cleaned easily and not require any expensive repairs .
Old Dec 4, 2003 | 01:33 PM
Black2000maxima's Avatar
it would only be an expensive repair because of the labor involved-I am pretty sure that whole intake section under the wiper blades has to be removed and they gotta take all the shiet outta there...
its time more than anything else...
been there, done that
Old Dec 4, 2003 | 01:34 PM
-Red-'s Avatar
I still find the "hissing" sound a little odd though. The sound I was hearing when a leaf would get stuck was more like ticking, which is a little more in line with something getting struck by the fan blades.
Old Dec 4, 2003 | 03:03 PM
IgS's Avatar
IgS
i got the same thing and its kinda ****ing me off
Old Dec 4, 2003 | 06:36 PM
NizanDrivn's Avatar
Its probably not relavant, I noticed when I washed my in-cabin filter, I got some noise coming from the blower. Re-seating the filter got rid of the noise....There's also a TSB for whiring coming from the blower motor....
ALSO, prior to reinserting the filter, I turn up the fan speed to max, I was surprised to see how much garbage flew out....
Old Dec 5, 2003 | 05:26 AM
greekmax2k1's Avatar
got the same problem....wen i turn the heat on it sounds like its coming from under the passenger dash.....after like 5 minutes it goes away but wen i make a right hand turn it starts again and then goes away wen i straigthen it out....still havent fixed it
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
