White Plastic Below intake
Old Dec 4, 2003 | 02:46 PM
Matto357's Avatar
So what is the white plastic (looks like a bottle or water trap of some sort) below the air intake? It hooks into the stock intake right before it goes into the air box at the bend. Was thinking of taking it out if it isn't something vital to free up some air flow.
Oh, it's right below the battery.
Old Dec 4, 2003 | 03:08 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Only older 2Ks have that...at least not 2K1+.
It's just a resonator box to quite down the intake growl. Not sure if it would help air velocity any.
Old Dec 4, 2003 | 03:10 PM
Matto357's Avatar
So taking that off wouldn't hurt anything at all? Sweet.
Old Dec 4, 2003 | 03:34 PM
IceY2K1's Avatar
No...but the bottom of the cold air scoop is closed on 2K1s, so you *MIGHT* want to close it or better run an hose to a cold air source like the ghetto airbox mod.
Old Dec 4, 2003 | 03:42 PM
Matto357's Avatar
Welp, the reason I mentioned it is because if I took off the white plastic part, it would look almost identical to a GAB that I saw pictures of on the org.
Old Dec 4, 2003 | 04:00 PM
Y2KSESteve's Avatar
A true GAB has holes cut in the air box before the filter, or the top part of the filter holder.
Old Dec 4, 2003 | 04:10 PM
IceY2K1's Avatar
"true"?
Pretty sure version 1.0 or maybe 2.0 doesn't.
Old Dec 4, 2003 | 07:02 PM
Loe max's Avatar
Its a resonator box. If you disconnect it and cover up the hole, the intake noise will not increase BUT you will feel slight engine vibration at high revs near the firewall/gas pedal area.
Fbana41
Aug 29, 2016 12:18 PM
hayne
Oct 5, 2015 11:53 AM
MaxDD
Sep 24, 2015 06:40 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
doctorpullit
Sep 10, 2015 06:33 PM
