Non-HLSD question
Non-HLSD question
I have an '03 6sp without the HLSD option. I know that it is supposed to send more power to the wheel with more grip. I also test drove a 6sp Max with this option when shopping and could definitely feel the difference coming out of curves and starting in a turn. It had definite advantages in those situations. I saw no real advantage to it for accelerating quickly in a straight line, however(at least one I could feel). My question is whether in a car without HLSD, like mine, are both front wheels being turned by the engine or is it just one of the front wheels that gets all the power all of the time? And if both are being powered in a non-HLSD car, is it a 50/50 split of the power to each wheel all the time? Also, what happens when one drive wheel begins to slip in a non-HLSD car?
This is kind of wrong, with a non-HLSD tranny its just a standard differential. That means the wheel with the least amount of traction is going to spin the most. So that means if one wheel was on dry pavement and the other is on ice, its going to spin like crazy on the wheel on ice. The car wont move.
There is no advantage there. Not to mention we have unequal drive shafts which usually cause the driver's side wheel to spin more if you in a staight line spin and causes torque steer.
Its only really a 50/50 split when both wheels have traction, after that, it is a 0/100 split. Cause its an open diff.
Dixit
Dixit
The odd part is when I do a really heavy burnout I smoke both the tires and get sideways and according to my VIN I dont have the HLSD. I have noticed that when the burnout is light or unintentional to begin with it is one wheel. I have also noticed that going around corners its easy to spin one wheel. I know this means I do not have the HLSD, but why do I have a two tire burnout when I really get on it?
Like dude above said, the reason why it pulls left initially when you burning out, its cause the driver's side shaft is almost 1/2 the length, thats torque steer. Thats why it does that. Then the passenger side starts slipping cause they both get about even traction while slipping. But its still pulling left.
Dixit
Dixit
Dixit
Dixit
Dixit
Dixit
You right, its not a 0/100 split, its more like 0/50 split. Cause its not transfering power. I meant to write that.
Dixit
Dixit
Unclejunebug
04-02-2016 05:42 AM
Stagnet04
10-11-2015 08:16 PM
