Proper jack points?
Old Dec 7, 2003 | 12:00 PM
3.0HO
Proper jack points?
Checked faq and the 5th page is mssing with the proper jack points.
What are the proper jack points on a 5th gen?
Old Dec 7, 2003 | 12:07 PM
Zero Deuce SE's Avatar
Do you have an owner's manual? The vehicle jack also has a sticker with the jacking points on it.
Old Dec 7, 2003 | 12:08 PM
Mick Max's Avatar
Wild at Hurt
On the sills between the 2 notches. Had an insert madefor my floor jack to fit those points. Rear axel if no sway bar.
Old Dec 7, 2003 | 01:14 PM
MyownNismo's Avatar
Future Camaro SS owner
What about jack stand point's.
Old Dec 7, 2003 | 01:21 PM
Mick Max's Avatar
Wild at Hurt
Ive had mine on jack stands by where the lower control arms meet the subframe. Worked fine.
But because this is a safety issue, i am gonna wait for somebody, to describe it better than me, to post up.
Beautiful car by the way!
Old Dec 7, 2003 | 01:46 PM
3.0HO
Thanks!
Also I cannot remove my stock jack from the back. Seems to be locked in there and cannot twist or pull it out like in the manual. Any suggestions?
Old Dec 7, 2003 | 02:12 PM
NYC TAR's Avatar
use strewdriver and stab in the hole and turn it loose.
Old Dec 7, 2003 | 02:26 PM
R max's Avatar
mount points
Heya 3.0 HO
I've been safely raising the car with a jack and a small 1x4 piece of wood for insulation under the rear axle, between my sway bar ( stillen ) and the moving suspension. placing the jack stands (with longer pieces of 1x4s about 4-6 inches ) under the frame portion of the car, be careful not to crush any of the line running on the inner driver side ( just alongside of the frame rails ) you will see several lines running along the frame toward the center of the car. try and find the frame portion that is most rear where the frame ends and place the pad just under the end and the welded frame
I haven't had any problems there for mounting points, but please make sure you block off the tires so the car doesn't roll in either direction.
I hope this helps
ran
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
