Tail-light fit
Old Dec 7, 2003 | 09:19 PM
schernov's Avatar
Tail-light fit
New member here....
Are the lights from 2000 or 2001 max - the ones that have black background color fit the 2002-2003? I am not really fond of the silver look...
Thanks!
Old Dec 7, 2003 | 09:28 PM
PearlWhtMaX2000's Avatar
Originally Posted by schernov
New member here....
Thanks!
yes i believe that they do
Old Dec 7, 2003 | 09:35 PM
Anuj's Avatar
yes they do but you will also need the 2k/2k1 harnesses as well
you cannot use the harness of the 2k2/2k3 for the 2k/2k1 headlight housing
Old Dec 7, 2003 | 09:38 PM
schernov's Avatar
I assume you are talking from experience? Is it hard to do the swap?
Old Dec 7, 2003 | 09:56 PM
ToYLeT902's Avatar
JET Speed Lab
the swap is easy, you just need the 2k-2k1 harness, plug and play. The ones with the black background is from a 2k-2k1 SE.
The only thing hard is taking the tail light out after removing the 4 screws in the back. (its hard because of the black silicone stuff they use to seal the lights in place)
Old Dec 7, 2003 | 09:58 PM
Anuj's Avatar
use a blow drier to heat some of the silicone thing up so you can make it loose
No I have not done this before but remember reading a thread on it
Old Dec 7, 2003 | 10:30 PM
limsandy's Avatar
Thanks, I was going to do this soon.
~limsandy
Old Dec 7, 2003 | 11:13 PM
maximilion's Avatar
What's all this talk about harnesses? I just bought my 2k1 taillights and plugged it right in. I didn't swap out a single piece.
Old Dec 8, 2003 | 12:19 AM
ToYLeT902's Avatar
JET Speed Lab
the 2k2 use's different bulbs, i think for the stop light.
Old Dec 8, 2003 | 01:57 AM
maximilion's Avatar
I have a 2k2, I guess I was just lucky - it was just like plug 'n play. Disconnect my stock 02's and connect the '01s.
Old Dec 8, 2003 | 05:07 AM
fishhouse's Avatar
YES...2k-2k1 tails will fit perfectly in 2k2-2k3s (and vice versa). you MAY need a harness - you can get it from you local Nissan parts department.
OR, you could always tint/smoke your stock tails to yourself make them have the black trim - and save alot of cash (probably $150-$300).
i did this on my 2k (which had all red taillights that i didn't like - i prefered the black trim SE style as well). the end result looks stock, was easy, and cost next to nothing.
check out my how-to i wrote here:
http://www.kevinfisher.net/web_serve...light-mod.html
Old Dec 8, 2003 | 05:10 AM
SoonerFan's Avatar
Cletus
i did the same thing, and used your writeup. thanks!!
Old Dec 8, 2003 | 05:13 AM
fishhouse's Avatar
or...in no time i'm sure you will have a dozen or so guys posting here to offer to trade you. most would disagree with you and prefer your chrome tails!!
although, a trade would be kind of hard - unless it was local and didn't require an exchange through the mail.
if you decide to buy, don't buy from Nissan - way to expensive. check ebay and our for sale section here on the ORG. local or online junkyards are also a great resource.
Old Dec 8, 2003 | 05:15 AM
fishhouse's Avatar
no problem! thanks for letting me know you used it...glad to know someone else found it useful!
Old Dec 8, 2003 | 06:20 AM
schernov's Avatar
Nice write-up! Do you have issues with black paint getting scratched easily, by any chance?
Old Dec 8, 2003 | 06:58 AM
skandalouz's Avatar
i didn't need any sort of harnesses either. i have a 2k3... an di got someone's 2k1 se tails... it plugged right up. only thing u gotta do is loosen the screws... and push the taillight out with a lot of force from the inside of ur trunk... you'll feel it begin to give way............
i guess u could use a blowdryer or something to loosen it...
Old Dec 8, 2003 | 08:36 AM
fishhouse's Avatar
no...no scratching. in my how-to i describe appling the clear coat spray. it serves two functions - to give the NiteShades spray tint a higher gloss AND to help protect the new tint from sratches. you shouldn't have a problem at all if you apply some sort of clear coat sealer.
Old Dec 8, 2003 | 11:35 AM
Manaz101's Avatar
Has anyone ever colored their lights the same color as their car? I wonder what that would look like? Anyone have pictures if done?
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
