service engine soon
Old Dec 10, 2003 | 01:06 AM
BEEI30's Avatar
service engine soon
i got these codes from obd 2 reader
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
P0505 - Idle Control System Malfunction
what does it mean and how do i fix it?
Old Dec 10, 2003 | 08:47 AM
Jeff K's Avatar
0420 is a software issue and your ECU needs to be reflashed with a new program. I just had mine done because my car through the same code. I have over 75,000 miles on my car so I had to pay for the updated software. Only good part of all this was that I got my first gear driveability issue fixed. No more bucking back and forth while in first gear. All '01 manual transmissions had this issue. Good luck.
Old Dec 10, 2003 | 09:17 AM
BEEI30's Avatar
i have over 65,000 miles on mine...so over the 60k warranty how much did you pay? i have an auto tranny. From 00-up I30/I35 all transmissions are auto.
Old Dec 10, 2003 | 09:24 AM
Jeff K's Avatar
It cost me $90 for them to tell me it was code 0420 which I told them and the reflash as $30.
As far as the tranny issue/ECU goes. The problem back then was all the comptuers were programmed for automatic transmissions and I just never went and had the TSB done. Done worry about it.
Old Dec 10, 2003 | 09:49 AM
BEEI30's Avatar
cool thanks
anyone know how to fix the idle contol system? while at idle or neutral, the rpm stays at around 1500 and pulses up and down from 1500 and 1900.
Old Dec 10, 2003 | 03:05 PM
Lawrenceismynam's Avatar
I just bought a 2k max with about 48k on it and the Service Engine Soon signal came on, the thing is that I don't feel a difference in the driving of the vehicle. I've had very bad luck with cars, what should I do?
Old Dec 10, 2003 | 03:30 PM
ktm250rider's Avatar
Isnt the ECU covered under warranty for 80k miles. I have the same code (0420) and im going in this weekend to get it fixed. Im aiming to have the warranty cover it.
shilov
Feb 19, 2024 09:40 PM
Pixel
Sep 15, 2015 05:53 AM
seesole
Sep 14, 2015 12:38 PM
Steven Orozco
Sep 12, 2015 10:41 PM
jfl330
Sep 4, 2015 01:44 PM
