Transmission Dipstick Clip 2002
On the 2002 (maybe other models) there is a clip on the transmission dipstick that holds it in the tube. After I refilled my tranny today, I put it back in and found the tranny was over the fill mark, but then I switched which side the clip was on and it was fine. Which side does the clip belong on?
I know you're supposed to check tranny fluid when hot...but will the fluid be under HOT when cold or over HOT when cold?
My 2002 only has a HOT marking. Where is the COLD marking in relation to that?
Just went to check...mine definately does not have a COLD mark. I pulled about 1/2 a quart out and it is right at the HOT mark now. I'll take a short drive and see where it falls while hot. Anyone know where the cold mark is on the dipstick?
Originally Posted by charliekilo3
I told you where it was in my previous post. The top notch on the blank side of the stick.
I took about 1/2 quart out and then went for a little drive with the wife to look at Christmas lights. I rechecked when hot and the level was right in the hash marks. Still not sure why I didn't get 4.5 quarts out today when I drained it.
Pied
Sep 26, 2015 03:29 PM
