Help with 2000 Maxima GLE
Old Dec 13, 2003 | 09:47 PM
SpecVcepS's Avatar
well, i just got this car for my mom, i traded in my 2002 Spec V.
there are some things that baffle me though.
i tried searching, but it says im not permitted.
im a regular on b15sentra.net
anyway,
The Service Engine Soon light is on, because the car was filled up while running, so is there any way that i can clear the code myself, like the procedure for the spec v. If not, i guess im goin to the dealer or autozone.
And when i get in the car, sometimes traction control is off. Other times its on. I dont turn it off or anything, its just off when i start the car. TCS Off & Slip are both lit up on the cluster.
Is this normal?
Old Dec 13, 2003 | 10:56 PM
SEdge
idk about traction control being off sometimes, but on a 2k/2k1 the ecu reset is as easy as disconnecting the battery overnight. i will caution you though, to only reset it yourself if you're absolutely certain you know the reason for the light...there could be another problem you don't know about, in which case its a good idea to have the code pulled. i believe only the negative terminal of the battery has to be disconnected for the reset.
Old Dec 14, 2003 | 10:31 AM
SpecVcepS's Avatar
if i disconnect the battery, am i going to need a code for the bose radio when i hook it back up?
Old Dec 14, 2003 | 11:11 AM
Maxpat82's Avatar
No!!
If it's O2 sensor (could be) the light won't came off!! (already try)
Maybe for a gas gap though!!
Old Dec 14, 2003 | 11:26 AM
Loe max's Avatar
If your TSC and SLIP lights are on, you have a problem with your TSC system
Old Dec 15, 2003 | 09:17 AM
SpecVcepS's Avatar
what could the problem be.
Old Dec 15, 2003 | 10:30 AM
BennysMAXIMA's Avatar
When I bought my used 2K SE all these lights were also on. TCS, Slip and SES and maybe even ABS. Brought it to Nissan and get codes pulled. Turns out it was Bad Coils.......
Old Dec 15, 2003 | 11:00 AM
SpecVcepS's Avatar
how much did that cost to fix? and if that is infact the problem with my Max, i still have 5k miles left under warranty, will it be covered?
Old Dec 15, 2003 | 11:07 AM
SkoorbMax's Avatar
Bad coils are $500-700 if the dealer does it. Do it yourself for $300. They are easy. Anyway, powertrain doesn't cover them (only 3/36). Don't jump the gun - if you have a code go and get it pulled at autozone, although if it ONLY occured by filling up with your engine on (something I often do but have not had a code from this yet), then resetting will probably keep it off.
Old Dec 15, 2003 | 11:18 AM
SpecVcepS's Avatar
im gonna have to go to autozone. the thing is, i got this car on friday, the dealer said to come back if the SES light does not go out by monday. its a CPO car, so nothing should be wrong with it. if it turns out to be bad coils or something else, they are gonna get a lot of *****ing and complaining from me.
Old Dec 31, 2003 | 11:11 PM
SpecVcepS's Avatar
coils it was.......replaced under warranty @ 70k miles.
Old Jan 1, 2004 | 05:51 AM
Y2KSilvahSE's Avatar
Your warranty replaced them @ 70K? I didnt think it went past 36k...
Old Jan 1, 2004 | 08:08 AM
bert's Avatar
I have often filled my car while it was running and never had an SES light due to this. AAMOF I have never had an SES light for a loose gas cap. All the SESs I have had were real. 1 faulty fuel level sender and one 02 sensor.
I have heard that if the problem corrects itself the SES should auto-reset after 5 starts or somthing like that. However, that is just what I heard, so it may be some pure and utter BS.
Take the 2 minutes and get the code read.
Old Jan 1, 2004 | 11:15 AM
SpecVcepS's Avatar
yup, warranty replaced them. the guy checked the codes.....and said the coil need replacing. so he replaced them, and the car finally ran like it should have.
Old Jan 1, 2004 | 11:50 AM
irvine78's Avatar
dude...why were you filling up your car while it was running?
in maximas, if you don't close the gas cap until you hear at least 2 clicks, it can throw off an engine light too...
it's amazing they replaced the coils at that mileage...wow...
Old Jan 1, 2004 | 11:51 AM
KLOOGY's Avatar
L33t BMW Drivah
Why are Post whoring today ? Mr Irvine rice ?
Old Jan 1, 2004 | 11:53 AM
irvine78's Avatar
that's one of my new year's resolution...
out-post Kloogy...
it's ridiculous how you have most posts than me.
Old Jan 1, 2004 | 11:58 AM
KLOOGY's Avatar
L33t BMW Drivah
out-post Kloogy...
Once again, your envy of me , comes to the surface.......
Dont drink haterade....its not good for ya !
Old Jan 1, 2004 | 02:40 PM
SpecVcepS's Avatar
because it was cold as **** and my sis was in the car. she was cold....so i left it running.
i know your not supposed to....but what the hell.
Old Jan 1, 2004 | 04:59 PM
KCMichaelM's Avatar
QUOTE - The Service Engine Soon light is on, because the car was filled up while running
I have filled up my Maxima with the engine running for 4 years. I've never had the SES come on once. That's 139,600 miles of gas. Doubt that caused it, unless the cap wasn't put back on tight.
Old Jan 1, 2004 | 05:01 PM
SC02Max's Avatar
Where's the best deal on coils? OEM?
Old Jan 1, 2004 | 05:18 PM
KCMichaelM's Avatar
Autozone sells Wells coils C1266 and C1267 for pretty cheap (~$50 each). Note those are 2000 part numbers. I installed those when mine went bad, they work fine so far.
Old Jan 8, 2004 | 08:47 PM
SpecVcepS's Avatar
thats probably waht happened. im glad i didnt have to dish out any $$ to get it fixed
halfpol
Oct 17, 2022 12:16 PM
CRizz
41
Jun 7, 2021 05:42 AM
rtirbany
Sep 8, 2015 11:46 AM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
