Tail/Brake Light replacement problem
Old Dec 14, 2003 | 06:11 PM
Chad Valk's Avatar
I haven't visited in a while and I notice that searching is now only for paid members. Unfortunately I am in a pinch tonight. I am trying to fix a burnt tail light and I purchased and installed the replacement bulb tonight. The new bulb works fine as a tail lamp when I turn on the lights, but the brake light does not activate. The other brake light (pass. rear) and the spoiler mounted 3rd both do. I checked fuses and they are in order. WHat else could this be?
TIA to those of you surfing this evening.
CV
2001 AE
Old Dec 14, 2003 | 06:19 PM
MacAlert's Avatar
You might have bought the wrong bulb. I don't know what size is used.
Old Dec 14, 2003 | 06:25 PM
Chad Valk's Avatar
I bought the Sylvania 7443 Stop and Tail lamp. Listed in the computer at the store I went to as the in stock replacement. It sure seems like the right bulb, but yes that thought did cross my mind.
Old Dec 14, 2003 | 06:33 PM
Mick Max's Avatar
Wild at Hurt
I had a similar issue simply because I did not push the bulb into the socket hard enough.
Those bulbs contacts come out of the bulb and are bent over. Once i had one that was bent over the wrong way, so compare that part to another known working bulb.
Old Dec 14, 2003 | 06:38 PM
Chad Valk's Avatar
Just before you sent your reply I just went outside and re-seated the bulb again (I had tried this a few times already). This time thought I turned the blub around just for "****es and ha-ha's".
It worked! Yeah. Okay, now I can go fire up the snow blower and clear the driveway. Oh what a beautiful night here in the northeast.
Thanks again Mick & MacAlert.
Old Dec 14, 2003 | 08:56 PM
Triple8Sol's Avatar
I miss the .org!
I'm guessing you bought a single filament bulb, when a dual filament is needed?
JMag90
Aug 25, 2015 09:17 AM
maxinout93
Aug 20, 2015 02:17 AM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
