Changing trans. fluid on a MANUAL ?
Old Dec 17, 2003 | 07:34 AM
Jerry13's Avatar
I was told that since my gears fail to shift smoothly, that I should change my trans. fluid.
ANY ADVICE on what kind of fluid, how much of the fluid, to put in. ALSO where is the drain plug for the trans. fluid located, what type of socket does she need, etc.
and ANYTHING else that might be important. THANKS
Old Dec 17, 2003 | 07:38 AM
Ammi's Avatar
350 Detroit Muscle
I personally use Amsoil. You could use Redline also.
Link to directions.
http://vbxmaxima.8m.com/mtoil.html
Contact talkinghorse from this board. He will give you a great deal on Amsoil Products.
2002 Maxima SE's Avatar
Check the FAQ in the fluid section.
Old Dec 17, 2003 | 07:54 AM
Lumbee1's Avatar
Piece of pie.
Look under car at bell housing. You will see two bolts. The lower one is the drain and the one higher up is the fill point. The tranny will take 2 1/2 quarts and you will need a pump to get it from the bottle up to the fill hole. When filling, make sure the car is on level ground because the signal you have put enough tranny fluid in is extra fluid running out. It is easy to do. Hope this helps.
Old Dec 17, 2003 | 08:01 AM
Colonel's Avatar
Old Fuddy Duddy
Originally Posted by Lumbee1
Piece of pie.
Actually, if you remove the intake snorkel only (part that has the temp sensor in it) you can use gravity fill method using only a funnel/tube setup. Thats how I did mine. Pretty easy to do.
Old Dec 17, 2003 | 08:55 AM
GregP's Avatar
I have a write-up with some pics on my site, if you care to see what it looks like on a 2002 6-speed.
http://www.greghome.com/Greg's%20Garage/2002MaxSE/MT-90.htm
Old Dec 17, 2003 | 10:26 AM
naerok's Avatar
How different if any is it from 2k1 5spd???
Old Dec 17, 2003 | 11:41 AM
MmaximaSE01's Avatar
when i changed the trans fluid 01, i broke the F-ing drain plug thing. On the 00-01 its like a sensor with a wire that goes into the trans. its held in by 1 bolt , so i took the bolt out and started prying cause it wouldn't come out, and guess what, it snaped....i glued it back. yeah thats right. im an idiot.
Old Dec 17, 2003 | 12:29 PM
naerok's Avatar
so it is different then...is there a write-up for the 2k1 TM??
Old Dec 17, 2003 | 01:09 PM
spirilis's Avatar
Yeah, my 2000 didn't have a drain plug, I had to remove the Reverse Switch (that sensor-ish thing with a wiring harness and a single bolt holding it in)
Be very careful with it.
The 2000 has a filler plug with a 1/2" indentation, like for a ratchet or torque wrench... no hex-head bolt.
Old Dec 17, 2003 | 01:32 PM
Larrio's Avatar
The Definitive AE Master
be very careful cause when you take out that wiring harness with the one bolt in it the fluid shoots out like crazy
mine was on a lift when I did mine and the tranny fluid went everywhere
Old Dec 17, 2003 | 07:44 PM
00MaxSE's Avatar
Pointy Elbows
How often do you guys change your tranny fluid?
Old Dec 17, 2003 | 08:20 PM
Ammi's Avatar
350 Detroit Muscle
Follow this for 2k or 2k1
http://www.max-world.org/writeups/5t...rannymt90.html
Old Dec 18, 2003 | 03:33 AM
ssheltz's Avatar
Originally Posted by Ammi
These directions are perfect for the 2k max. I changed mine 2 weeks ago to redline MT90 and it made a huge difference in shift smoothness, especially when it is cold out.
Old Dec 18, 2003 | 04:41 AM
skinyc15's Avatar
Is there a particular milegage that this is recommended to do or just do it when you feel you are not shifting smoothly. I have a 2k2 manual.
Old Dec 18, 2003 | 06:56 AM
spirilis's Avatar
I've heard every 30K miles is a good rule of thumb...
Old Dec 18, 2003 | 07:10 AM
naerok's Avatar
Thanks for the info.. im still worried about the sensor...
captchaos
Mar 15, 2016 12:18 PM
pjgreek
Sep 9, 2015 09:30 PM
ag90fox
Sep 9, 2015 12:22 PM
flu2000
Sep 8, 2015 02:23 PM
pktaske
Sep 4, 2015 08:40 AM
