Ignition Coils
Old Dec 21, 2003 | 07:12 PM
leekc75's Avatar
Ignition Coils
Around what mileage have the ignition coils been going out?
2001 SE
Old Dec 21, 2003 | 07:35 PM
skalberti's Avatar
I live life on the edge
2001 SE
Mine went out at about 50,000
Old Dec 21, 2003 | 10:08 PM
00MAXI's Avatar
Mine went out at 82k but still they should have lasted at least 100k
Old Dec 22, 2003 | 06:39 AM
DanL's Avatar
2001 SE
I had one fail hard at 47K, but now that I've replaced all six, the
idle is now completely smooth (used to have an intermitent miss).
Since it's been doing that since about 38K I'm assuming the coil
started to fail back then.
Old Dec 22, 2003 | 10:05 AM
Lawrenceismynam's Avatar
how do you know when your ignition coil is failing?
Old Dec 22, 2003 | 11:32 AM
DanL's Avatar
I don't think there is any easy way to know for sure until it gets bad
enough to throw a code and set the SES light. But if your car is
missing at idle and/or you hear an occasional pinging sound there's
a decent chance you have a coil going bad.
Old Dec 22, 2003 | 01:21 PM
milellie111's Avatar
What does pinging sound like??
Old Dec 22, 2003 | 01:45 PM
purekoryo's Avatar
ping... ping... ping-aling.. ping.. ping.. ping....
Old Dec 22, 2003 | 04:21 PM
skalberti's Avatar
Hold on folks......... i think we have a hit on our hands.
The noise you will most likely hear is a cross between BB's in a can and a diesel engine.
Old Dec 22, 2003 | 04:25 PM
KCMichaelM's Avatar
129K on mine, replaced with Autozone
Old Dec 22, 2003 | 04:26 PM
ZIPPIN's Avatar
Mauja He Mauja
can bad ones cause bad mileage?
Old Dec 22, 2003 | 04:28 PM
KCMichaelM's Avatar
Sure will.... The cylinder won't fire and the fuel that was added to that cylinder is wasted, i.e. never turned into power.
Old Dec 22, 2003 | 06:08 PM
pauly47's Avatar
My coil went at 65K. Anybody know how much the part costs (not including labour)
Old Dec 22, 2003 | 07:22 PM
2kGLE's Avatar
my car is in the shop getting new coils and plugs installed right now.. the coils were shot before 60k.
Old Dec 22, 2003 | 07:32 PM
DanL's Avatar
Check the parts faq. Six coils + shipping from David Burnette (South Point Nissan) will run about $308 -- just over $51/each. His number is 888-254-6060. Email is daveb@adpub.com. You can replace them yourself in less than an hour. All you need is a 4mm allen wrench (to remove the front cover), a screw driver to depress the release clip on the connector, a 10mm socket and a ratchet + 10" extension. Each coil is held down with a single 10mm bolt.
Old Dec 22, 2003 | 10:00 PM
darrelfsu's Avatar
At 55,000 miles, I have 5 coils being shipped courtesy of DaveB.
Old Dec 23, 2003 | 12:33 AM
skalberti's Avatar
Dude, you could have done the whole job yourself in an hour for under $500
Old Dec 23, 2003 | 06:38 AM
Y2KSilvahSE's Avatar
My 2k coils were garbage at 30k. Dealership DID replace them for nuthin gladly. What a huge difference in performance after they put the new ones in.
Old Dec 24, 2003 | 12:23 AM
panda_1's Avatar
ima steal my new ones from my neighbors max. shes trading it in
Old Dec 29, 2003 | 09:43 AM
pmorton's Avatar
The SES light is on. The code that Auto Zone shows says something like catalyst fault - right bank. The engine does miss and back fire occassionally. Could this be coil(s)? Can you check individual coils with OHM meter?
Old Dec 29, 2003 | 10:31 AM
mclee45's Avatar
does the extended warranty cover the ignition coils?
Old Dec 29, 2003 | 02:07 PM
ChickenWing's Avatar
yea is this covered by warranty?
I'M LOOKIN AT A 2000 MAX WITH 21K MILES (original warranty)
Old Dec 29, 2003 | 02:27 PM
allenmason's Avatar
This one is most likely not a coil problem. What code came up? Common catalyst related codes are P0171 "Bank 1 Lean" which is usually is accompanied by the engine running rough or surging when cold. If so, your MAF is going. A P0420 "Catalyst Efficiency Low" is another common one on the 2K Max. this one requires the ECU be reprogrammed at the dealer.
Old Dec 29, 2003 | 03:53 PM
KCMichaelM's Avatar
Doubt you still have a warranty on that car at all. I bought a 4 yr 100k extended warranty b/c I drive alot. Most warranties up after 3 years.
However, yes it would be covered... Almost ANY SES code you would see would be covered, but I greatly doubt they would replace coils unless it trips a code.
Old Dec 29, 2003 | 04:09 PM
twinpower's Avatar
Don't know if my problem is related to the ignition coils... I'm about to replace them, haven't heard a pinging noise or had any idle problems, but I do have a 2000 max with 111,000 miles (original coils)
Perhaps allenmason just gave me some insight, but (often enough) in the morning (when I first start my car), when I'm in 2nd or 3rd gear (5spd) and I give it about 50% or 75% throttle, the engine will 'lag' more than it does after it has warmed up... that is to say, in the 2000 - 3500 rpm range, I get about 50% of the power I should. When I hit 4000 rpm, the engine perks up back to normal and I'm able to get my go-fast on. That doesn't bother me so much, because I rarely ever want to speed in the morning, but sometimes the car shakes violently (mostly in a 3rd gear) like it's experiencing a fuel cut around 2-3.5k rpm.
I have to push in the clutch, and the problem goes away. Only does it while the engine is cold, and it has only happened 4 or 5 times. Could this be a MAF issue as allenmason has alluded to, or is this a sign of the ignition coils going out? Maybe something else? I don't even really know what the MAF does, so I have hardly any idea what a symptom of its imminent failure would be. Thanks.
Old Dec 29, 2003 | 04:28 PM
i think most cars are much slower when cold
not to mention fuel economy = teh ****
i have a ka24de ... which is indestructible for a good 200,000 miles - and performance (as non existant as it is) ... is the last thing on the menu for breakfast
Old Dec 29, 2003 | 04:30 PM
SterlingMist00's Avatar
Why does this code require an ECU update? I just got this same code (P0420) pulled. Is there anything wrong with the cat or the o2 sensors.
Also got this code pulled - 1320 - anyone know what that means? It is not explained by the reader...
Old Dec 29, 2003 | 05:19 PM
ZIPPIN's Avatar
Mauja He Mauja
nice wheels,,,looks like you are ready for 4-wheeling
Old Dec 29, 2003 | 06:44 PM
Loe max's Avatar
My coils didn't fail, they just acted up when moisture gets inside the plugs but functioned fine otherwise. The sound is something similar to a person gargling on water.
Old Dec 29, 2003 | 06:56 PM
MrGone's Avatar
my dad has about 87k on his car, started to develop a studder. switch to copper plugs, went away
Old Dec 29, 2003 | 07:28 PM
Snolife's Avatar
What we have here is a failure to communicate
I have an 03 GXE and man this thing has started pinging like crazy, what are the chances that this could be the ignition coils? and so soon at 20,000 miles? Took it to the dealer and said it is normal, blah blah blah. This is NOT normal.
Old Dec 30, 2003 | 07:47 PM
Snolife's Avatar
No suggestions?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
