TPS Sensor help!
Old Dec 23, 2003 | 11:42 AM
Tally Max's Avatar
TPS Sensor help!
i am putting on nitrous on my 2k2, but i am having problems figuring out where my tps sensor is so i can hook up the WOT switch. if someone could please help me out i would very much appreciate it. this would be in the n20 forum but not too many people look in there. thank you in advance
Old Dec 23, 2003 | 11:49 AM
skandalouz's Avatar
we have a drive by wire system.. so i'm not sure that we have a TPS... if we do, i coulnd't find where it was..... i had to use the switch and put it near my pedals so that at WOT the switch will be pushed and activated...
Old Dec 23, 2003 | 12:08 PM
Zero Deuce SE's Avatar
It's located within the electric throttle control actuator. It works in conjuction with the Accelerator pedal position switch. The plug for the TPS is the green plug going into the unit connected to the intake on the other side of the MAF. The blue, white, black and red wires are used for the TPS.
Old Dec 23, 2003 | 12:14 PM
skandalouz's Avatar
so i can actually hook up an electronic WOT switch??
Old Dec 23, 2003 | 12:23 PM
If you don't mind tapping into your electronics. The wires from the TPS give feedback directly to the ECM. The range for voltage is 0-5V depending on the position of the APP switch. Maybe they make a plug in interface for the NOS system.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
