Quick question on sway bar install
Old Dec 25, 2003 | 08:48 AM
MacAlert's Avatar
I got a Progress Rear Sway bar. I was planning on installing it using ramps instead of the jackstands because I only have access to ramps. I have one question about the install, will the brake lines have to be removed to install the bar?
Old Dec 25, 2003 | 09:02 AM
Ammi's Avatar
350 Detroit Muscle
You will need to remove a bolt that holds the parking brake line.
Old Dec 25, 2003 | 09:29 AM
PhxBlue's Avatar
MK3 Supra and Focus ST
What he said /\ /\
Old Dec 25, 2003 | 10:39 AM
MacAlert's Avatar
Do I relocate the bolt or does it bolt up in the same place?
Old Dec 25, 2003 | 10:05 PM
RichSpidizzy's Avatar
My understanding is that there should be a bolt extension included w/the sway bar kit. The bolt goes right back where it started after the bar is installed. Can someone else confirm this?
Old Dec 25, 2003 | 10:06 PM
MacAlert's Avatar
I didn't get any bolt extensions. Guess I need to figure something out for this. More input please.
Old Dec 25, 2003 | 10:09 PM
Ammi's Avatar
350 Detroit Muscle
If the kit doesn't supply a separate bolt, you should be able to use the same bolt you took off.
Old Dec 25, 2003 | 10:17 PM
PoLo's Avatar
2-Wheelin it...
if you want, i can help you put it on...i'm in jackson heights and i got a pair of ramps......let me know...
Old Dec 25, 2003 | 10:30 PM
MacAlert's Avatar
If you have a torque wrench, I also need to install a strut bar. I will let you know once I pick up the bar. Thanks.
Old Dec 26, 2003 | 07:09 AM
PoLo's Avatar
2-Wheelin it...
if i can find my 14mm, then yeah, i can do that too. if not, then just bring a 14 and we're good to go mang.
Old Dec 26, 2003 | 07:21 AM
MacAlert and PoLo, this is too funny:
I'm going to PoLo's some day so he can help me with my Hella horns install.
MacAlert is going there for RSB and FSTB install (FSTB he's buying from me)
I also have a Stillen RSB I need help installing.
And I know PoLo wants to rewire his Hella's.
So, the three of us should coordinate and just all meet up together and knock it all out in one quick afternoon.
BTW PoLo, like I said, I refuse to show up empty handed. I found something which you may find very useful (If you don't have one already). I'll bring it whenever we decide to meet up
EDIT: I have a 14mm if PoLo doesn't find his and MacAlert doesn't have one.
Old Dec 26, 2003 | 08:16 AM
MacAlert's Avatar
Sounds good, I also have a 14mm. We could make a little mini meet out of this.
Old Dec 26, 2003 | 08:36 AM
PoLo's Avatar
2-Wheelin it...
so how's about tomorow around noonish...who's place...i have a yard, i can fit 1 car on ramps and 1 on the driveway.....or does someone have a bigger place....
Old Dec 26, 2003 | 09:00 AM
noonish works for me.... my driveway is a little too narrow to work in. Unless Mac has something better we could use, I think your yard might be best.
Mac, check your voicemail
Old Dec 26, 2003 | 09:04 AM
MaximaPolak's Avatar
Damn i want to get in on this. I have nothing to install yet. Things are on the way.
Old Dec 26, 2003 | 09:22 AM
PoLo's Avatar
2-Wheelin it...
sorry, only 2 .orgers at a time can stare at my car...
my yard is perfect...mac, hit me or rich up on aim...MGalvis01
Old Dec 26, 2003 | 03:52 PM
SEmy2K2go's Avatar
Go BUCKS!!!
I have the Progress RSB on my car and the installation was fairly simple. In regards to the brake lines. You will have to remove the ABS braket and once you install the RSB brackets, you pretty much will be limited to re-attaching the brake lines by zip ties. This is the way I installed mine over the summer from directions I found on the .org. Sadly, Progress does not include a ABS relocation bracket, so you'll have to improvise. Good luck. Took me about 30 minutes overall.
Old Jul 16, 2008 | 01:00 PM
hi-tek22's Avatar
bumping this old thread for assistance, im finally going to be getting around to installing my RSB, BUT i cant seem to find directions...and the directions in the FAQ's link to different threads about someones wheels
any one care to chime in?
Old Jul 16, 2008 | 01:12 PM
SoonerFan's Avatar
Cletus
my favorite thing on the org? bumped threads
it isnt that hard to figure out
Old Jul 16, 2008 | 04:04 PM
sublime258's Avatar
It would help to know whether it's a Progress or Stillen RSB.
Old Jul 16, 2008 | 05:26 PM
johnnyd2k2's Avatar
here is a how to link its for an addco rsb but it should be the same
http://www.moodym.com/maxima/tech/addcorsb.html
Old Jul 16, 2008 | 06:24 PM
SoonerFan's Avatar
Cletus
addco = progress
Old Jul 16, 2008 | 06:56 PM
hi-tek22's Avatar
oh its a progress....sorry about that, its in my sig, and while i was typing the initial post, i meaninglessly left that bit of info out
Old Jul 16, 2008 | 06:57 PM
hi-tek22's Avatar
kool, good lookin
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
ef9
Aug 27, 2015 07:21 AM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
