slip, tcs and abs lights all came on
Old Jan 1, 2004 | 01:50 AM
Akkord29's Avatar
My mom has a AE and the slip, tcs and abs lights all happen to come on this morning. The car was bought used and didnt come with an owners manual so i really dont know what this means. Has this happened to anyone. I cant search cause im not a paying member. sorry
Old Jan 1, 2004 | 01:58 AM
jattmax's Avatar
i aint no expert, but common sense tells me thats not a good thing lol
Old Jan 1, 2004 | 08:05 AM
Akkord29's Avatar
lol i figured that much....i was gona take it to nissan but its new years so thats not gona help much.
Old Jan 1, 2004 | 08:25 AM
2k3TitaniumSe's Avatar
I think it's the speed sensor. Did you odometer stop giving you you speed?
Old Jan 1, 2004 | 08:38 AM
sascuderi's Avatar
When the coils begin to go three warning lights come on (a very common problem on the 2000-01 max), but usually its the slip, tcs and check engine (not the abs). Is she sure the third light was the abs and not the check engine?
Old Jan 1, 2004 | 02:11 PM
Akkord29's Avatar
ya i drove the car too and i saw the three lights came on. So you think i have to change out the coil packs? anyone who can use search give me some tips on how to change them and where to get them. thanks
Old Jan 1, 2004 | 02:37 PM
DanL's Avatar
Before you spend $300+ on new coils, bring it to Autozone and have them pull the code(s) for you to verify that is indeed the problem. But if that is the problem call Dave at South Point Nissan (888-254-6060) and mention this forum. Six new coils + shipping will be just under $310.
Old Jan 1, 2004 | 03:00 PM
Akkord29's Avatar
But the check engine light is not on...so what codes would they check. do the other three lights that come on mean something as well....
also why would the slip and tcs lights go off if the coils are going bad...that doesnt make much sense to me...
Old Jan 1, 2004 | 04:06 PM
DanL's Avatar
Sorry, didn't read the entire thread and misread one of the replies to read that the SES was on as well. I wasn't saying it was your coils (doubt it is) which is why I recommended getting the codes first before doing anything.
There is a procedure to get the ABS light to flash an error code. You can find the procedure documented in a Haynes manual (involves grounding a pin on the data link connector by the fuse block). You can also reset the light by grounding the same pin three times within 12 seconds, each time for a duration of one second. I'd suggest investing the $15 or so and picking up the manual since the procedure is a little hard to describe here.
Old Jan 2, 2004 | 09:08 AM
Akkord29's Avatar
i called a few nissans around and one said its your abs and the other said its your alternator. haha another journey.
Old Aug 2, 2008 | 11:48 AM
m40601's Avatar
I just had the same issue on my 1999 maxima. I am still investigating. My brakes seem to be working fine so far. I recently changed my rear brakes about a year ago I guess.
Old Aug 2, 2008 | 01:14 PM
wyche89's Avatar
i was thinking alternator... i'm surprised no one has said that yet... you might wanna go to autozone and have your alternator tested for free, so you can at least rule that out as an option
Old Aug 2, 2008 | 09:37 PM
m40601's Avatar
I got my battery changed because the test at Advance showed that it was only running at half the cranking amps and of course they couldn't check the alternator without a good battery. Anway, they checked the alternator and it shows good condition. I will drive it a couple of days to see if the codes clear.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
maximusrising
Sep 2, 2015 09:55 AM
