Clutches
Old Jan 14, 2004 | 12:01 PM
PhatMax's Avatar
Clutches
OK, Here I am with a new suspension, reprogrammed computer, all the rest of the standard small upgrades and 54000 miles. I can tell my clutch needs some adjustment, and I want to know two things.
First, how many miles are stick shift drivers getting out of their clutches before adjustment and does the adjustment help eliminate a fully engaged clutch that slips once in a while? Ancillary to that, does it help the clutch begin to engage sooner during the pedal release?
Second, has anyone put an upgraded clutch on their normally aspirated 2000/2001 Maxima and if so what brand and stage level? Are you happy with the results?
Thank you for your help.
Old Jan 14, 2004 | 08:09 PM
Maxpat82's Avatar
Maxima have hydraulic clutch, so else than bleeding there's no adjustment!! If it slip, it's probably cause too much of abuse
You can change the travel of the clutch pedal (Don't remember were i've see that)
For the perf clutches:
Yes some org members have done it.
I've seen someone with a SPEC clutch and Fidanza flywheel!!
If you changed it, take a performance one!!
Take a look at http://www.specclutch.com/ and you're gonna have an idea!!
Old Jan 14, 2004 | 08:31 PM
Ben's Avatar
Ben
First, it is possible to change the clutch peddal travel.
However, if the clutch is slipping, it is most likely about to go. I would get it to a shop soon to be inspected.
I plan on going with the ACT clutch when mine finally gives.
Good luck.
Old Jan 14, 2004 | 09:50 PM
Ammi's Avatar
350 Detroit Muscle
GD on ACT Clutch. Real good price. Smooth engagement w/ 33% more holding power than stock.
http://forums.maxima.org/showthread.php?t=277548
Old Jan 15, 2004 | 07:33 AM
panda_1's Avatar
Iwas Planning A Stage Ii Act With A Heavyduty Pressure Plate And A Fidanza Lightenened Flywheel. Only Whn Mine Gives Though.
Old Jan 15, 2004 | 07:56 AM
PhatMax's Avatar
OK! This is great information. A stock clutch disc and pressure plate from Nissan is $215 so $269 plus shipping is a negligable difference. Even Stealin's price of $345 is not deadly.
Now comes the whopper......Given the proper tools and access to a lift, how hard is a clutch install?
I do have the real deal Nissan shop manual, so I have all pertinent info.
Old Jan 15, 2004 | 10:53 AM
Ammi's Avatar
350 Detroit Muscle
I'm assuming you have to drop the tranny. Time consuming job I say.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
