How to get rid of SES glitch...
Well we have had the car about 4 months and put on like 4k miles in that time.....we have had 3 SES lights already........the first was said to be a emmisions glitch, the second went away by itself after I used Mobil. (i filled up with shell which is said by some to cause strange things SERIOUS!!).
and now the light is back on...........its seriously so stressful for me.
how much do those ODB things cost? maybe its worth it just to buy one....DAMN.
Any thoughts on the wacked computer system??
It looks like they are going anywhere from $50 - $150
http://search.ebay.com/search/search...t&query=obd+II
I've had my light come on twice in the past month something about a heated Rear 02 sensor.
SES- been there...
Here's the deal- you need to cinche up the wires going into the ECU with 18" plastic ties. The harness gets loose and trips codes. The computer is located to the right of the gas pedal and also access it from the left foot area of the passengers side. Snug the wires up good- not too too tight but firm. There is a TSB on this procedure. If after doing this and getting it reset at autozone it still kicks on, get the reflas from the dealer $80.00. If your still having problems, read the code, could be an 02 sensor. The best and cheapest place to get quality Bosch 02's is from www.discountoxygensensor.com. FYI, Bank 1 Sensor 1 or P0135 (common code) is the first sensor on the firewall side- about 10" below the rear cylinders- toward the passengers side. If you ignore the light and it is running rich for a long time, you can damage the cats and get bad mileage.
This is the code that I got
P0141 - Sensor Heater Circuit Malfunction Bank 1 Sensor 2.
Would this TSB apply in this case?
NTB02-051a
NTB02-051a
NTB02-051a
NTB02-051a
re: 02
Couldn't open the TSB but before you spend $ on 02's, snug up the ECU with 2 plastic ties- reset at Auto Zone, then Reflash, only then replace the 02 and reset. FYI, senor 2 bank 1 is the one that is in the cat.
For reference, bank one is the firewall side since that is where #1 cylinder is, bank two is radiator side.
To make your life very easy;
Bank 2 Senosor 1 has a Blue sheathing over the wires
For some weird reason they refer to the front radiator side as the "rear"
Bank 1 Sensor 1 has a black sheathing
Your Sensor Bank 1 Sensor 2, if in fact thats the problem has a white sheathing. It's in th cat under your engine.
Bank 2 Sensor 2 has a red sheathing
r
r
NTB02-051a
NTB02-051a
spencerwh1
Jun 30, 2016 05:44 AM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
homewrecker
Sep 23, 2015 03:41 AM
