Airbags
Old Jan 19, 2004 | 09:48 AM
VMAXiMA2001's Avatar
Airbags
Hey guys,
Anyone know what to do when the airbag light starts to blink? Went over the 36,000 mile warranty and don't want to go in to Nissan and get charged up the @$$ if I dont have to. Thanks in advance.
Vinny
Old Jan 19, 2004 | 09:55 AM
dmplus's Avatar
When my airbag light started to blink on my 95 (50000 miles) i took it into the delarship and they reset the light for free. But I read somewhere on the forum you can reset it yourself doing something with the drivers door dome light thingy or something like that.
Old Jan 19, 2004 | 10:23 AM
DanL's Avatar
Here's the 2K+ reset procedure courtesy of STUDMAN and Maxcosity:
Note: Timing is KEY, use a stopwatch if you have to.
1) Turn IGNITION on (but don't start car)
2) After the AIRBAG warning lamp lights for 7 seconds and then goes out, turn IGNITION off within 1 second.
3) Wait 4 seconds
4) Turn IGNITION on (but don't start car)
5) After the AIRBAG warning lamp lights for 7 seconds and then goes out, turn IGNITION off within 1 second.
6) Wait 4 seconds
7) Turn IGNITION on (but don't start car)
8) After the AIRBAG warning lamp lights for 7 seconds and then goes out, turn IGNITION off within 1 second.
9) Wait 4 seconds
10) Turn IGNITION on (but don't start car)
11) Wait 3 seconds
12) Turn IGNITION off
13) Wait 2 seconds
14) START Car
15) Turn IGNITION off
16) Wait 2 seconds
17) START Car
AIRBAG warning lamp should blink for 7 seconds and then go out and never come back on. If it does, then you have a problem.
Old Jan 19, 2004 | 10:25 AM
white m3 guy's Avatar
i think airbag might be covered over the factory warranty as long as they havent been replaced but im not sure
Old Jan 19, 2004 | 10:28 AM
DanL's Avatar
Unfortunately they're only covered by the 3/36 warranty. The seatbelts are covered for the life of the car though.
Old Jan 20, 2004 | 08:24 AM
Thanks DanL.. I gave it a try last night and it worked.. thanks again .
BTW, would anyone know the airbag reset sequence on a '96 Maxima? (my mom's car just lit up). Thanks in advance.
Vinny
Old Jan 20, 2004 | 08:54 AM
Colonel's Avatar
Old Fuddy Duddy
Mine
Blinked while under warranty and it turned out the seatbelt sensor was bad and they had to replace the whole seatbelt assembly.
Old Jan 20, 2004 | 03:04 PM
DanL's Avatar
Vinny
- Turn the ignition switch to 'on' but don't start the car.
- Press the dome light switch in the door jamb seven times within 10 seconds.
- Turn off the ignition switch.
- Start the car. The light should turn off after a few seconds.
If it comes back on, get it checked. Don't want your mom driving around
with without a working airbag.
Old Jan 21, 2004 | 01:57 PM
Thanks again DanL.. I'll give it a try when I get home. Hope it works. :-D
Vinny
ThomasofSodor
Mar 22, 2018 08:18 PM
ToTheMax305
Sep 23, 2015 09:11 PM
Colossus
Sep 9, 2015 05:46 AM
kirkhilles
Aug 8, 2015 10:53 AM
