squealing noises on start
Old Jan 19, 2004 | 10:08 AM
takkar's Avatar
Don't know if this has been posted here....
Got a 2001 SE Auto and i hear a squealing noise from the left of the engine ( where the belts are) when i start the car in the morning...it is kinda cold here..but is this normal?
Old Jan 19, 2004 | 10:26 AM
DanL's Avatar
Good question. Mine does the same thing when it's very cold. Last about a second.
Old Jan 19, 2004 | 10:38 AM
takkar's Avatar
Mine continues till the engine temp reaches a good and high temp...it lasted for more than 5 minutes yesterday....I drove off after that and after 5 minutes stopped and checked and the noise was gone.Are you getting it from the belt area which is left of the engine?
Old Jan 19, 2004 | 10:56 AM
black2kse's Avatar
Sounds like a loose belt. Check the tension on the belts
DanL's Avatar
Yup. It only does it when it's really cold (ok, 'really cold' in Maryland is 20 degrees F or lower which is probably considered balmy in your neck of the woods), but it stops so quick I can't pinpoint where the noise is coming from. My noise is LOUD and almost sounds like a dry bearing.
Old Jan 19, 2004 | 11:15 AM
spirilis's Avatar
Mine makes a squealing noise sometimes at <20F temps coming from the starter... almost like the starter solenoid is sticking. Doesn't last long though...
Old Jan 19, 2004 | 11:34 AM
takkar's Avatar
but if it is cold..then how can the belts become loose? Dont the belts shrink in the cold? Loose belts would most likely be in the hot temp areas...I dunno..just a shot in the dark
Old Jan 19, 2004 | 12:23 PM
Nyc2kMax's Avatar
That's a definate loose belt. Check the tension on the belts.... I heard the same noise in mine tighten the belts noise went away
Old Jan 19, 2004 | 12:43 PM
takkar's Avatar
So for you guys..did the noise go away when the engine warmed up..or was it all the time?
Old Jan 19, 2004 | 04:45 PM
zgrm100's Avatar
I have the same problem. A loud whistling. I think it might be the belt. Any1 know how to tighten them?
Old Jan 19, 2004 | 07:08 PM
Mom's2kGLE's Avatar
Mine does the same thing when really cold and my belt is new, I put some belt dressing on and tightned the belt and it seems better no loud squeal on start.
Old Jan 19, 2004 | 07:37 PM
PearlWhtMaX2000's Avatar
yeah mine also does this in cold. for like 1 sec. how doi tighten the belt?
Old Jan 20, 2004 | 01:18 AM
BrandonSE's Avatar
Its the starter. There is a DIY thread that explains how to regrease it so the sound stops. I believe its in the Installation and howto section. Check it out, it worked for me.
brandon
Old Jan 20, 2004 | 06:41 AM
bert's Avatar
I had the same thing. It was loudest when cold but still stayed there when hot, much quieter though. A new alternator, courtesy of Nissan warranty fixed that. My alternator died.
Old Jan 20, 2004 | 06:58 AM
takkar's Avatar
Could the problem of loose belt be related to a high pitch whine at 4,000 plus RPM?
Old Jan 20, 2004 | 09:49 PM
zgrm100's Avatar
any1 know how to tighten the belts?
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
trungg86
Sep 4, 2015 04:58 AM
