Amp Install in stock Bose
Old Jan 20, 2004 | 01:24 PM
twllin's Avatar
Has anyone done this? If so do you need anything Special to do it? Does it have RCA's in the back? Im planning on puttin a sub in and I appreciate any help
Old Jan 20, 2004 | 01:41 PM
Rogo02SE's Avatar
No RCA's out the back, most people use hi/low converter and tap into the rear sub for audio. Your local Best Buy, Circuit City type of store can supply you with the converter and give you install info for free when you pay for the converter.
Old Jan 20, 2004 | 02:08 PM
twllin's Avatar
Is this the same thing as a line out converter? they have them at radio shack for pretty cheap if its the same thing. thanx for the help
Old Jan 20, 2004 | 02:24 PM
ChromeSE5's Avatar
the ones at radio shack are kinda crappy compared to the one i got from best buy. The pricing difference is noticeable but so is the quality. If you have a friend who works at best buy you can get them for about $5
Old Jan 20, 2004 | 03:08 PM
twllin's Avatar
How much are they normally there?
Old Jan 20, 2004 | 09:41 PM
panda_1's Avatar
So Basically You Use A Line Out Converter To Go From Any Speaker To The Rca's Then To The Amp? If Yes Wha Do You Use For A Remote Cable?
Old Jan 21, 2004 | 01:40 AM
ChromeSE5's Avatar
Normally $19.99 and the radio shack ones are about $7.99.
30585 - i haven't used the remote cable on either one of them and it still works fine.
Old Jan 21, 2004 | 02:09 AM
SEmy2K2go's Avatar
Go BUCKS!!!
You have to run some sort of remote lead to the AMP so it will turn on
30585 - not sure if its the same on the 2000 as the 2002, but you can tap into a +12 volt source (solid yellow wire) which turns on with the ignition on the back of the head unit...as mentioned, not sure if the wiring diagram is same for 2000 as 2002...may want to confirm prior to doing this.
Old Jan 21, 2004 | 02:18 AM
ChromeSE5's Avatar
Haha my bad... i though he meant from the input converter. Another way to get a remote lead signal is using the cigarette lighter. The amp will always be on if your car is on but it will shut off once you shut your car down. Thats what I did since I used the stock deck.
Old Jan 21, 2004 | 05:24 AM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
twlln ... holla at me on IM ill hook ya up
Old Jan 21, 2004 | 05:51 AM
SoonerFan's Avatar
Cletus
i want a hook up to
i would like a little more bass but dont want to have to change my HU
Old Jan 22, 2004 | 09:57 AM
twllin's Avatar
thanx for the help guys 2k2phat u should let this other guy have it for that price thats a steal imma get an indash DVD soon so imma have to replace it anyway thanx guys
Old Jan 22, 2004 | 10:44 AM
adamlee2001GXE's Avatar
I want the hookup too!
Old Jan 22, 2004 | 01:38 PM
2k2PhatMax's Avatar
u got a pm...
Old Jan 22, 2004 | 10:10 PM
02MaXiMa_GLE's Avatar
Go to the AUDIO FORUM FAQ
Read through STUDMAN'S second post... all the info you need is there. A simple line-out converter will not do. You need the PAC-OEM NISS kit. I installed it in my 2k2 w/Bose and it works great.
I also have a post or two in the Audio Forum explaining it a bit...
G
Old Jan 23, 2004 | 03:32 AM
cobymoby's Avatar
You have to add the PAC adaptor. It's not a hi-low converter but it converts the balanced Bose signal to an RCA signal. I built my system with it, works great. I have two more brand new PAC adaptors and one used one if anyone wants.
Here's a link to my old system. Shows that with a little know how you can build a decent system with the stock Bose head deck.
http://forums.maxima.org/showthread.php?t=277164
Old Jan 23, 2004 | 03:35 AM
cobymoby's Avatar
Go here to see a bunch of other pics. Hope this helps!!
http://cobymoby.home.mindspring.com/Audio%20System/
Old Jan 23, 2004 | 10:28 AM
twllin's Avatar
How much u sellin the used one and the new one for?
6spd4dsc
May 9, 2022 12:30 PM
melteye
May 16, 2016 12:02 AM
homeyclaus
Sep 3, 2015 06:15 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
