View Poll Results: So what springs are you running on your Max?
Eibach
228
16.59%
H&R
126
9.17%
Maxspeed
92
6.70%
Tein H-Tech
91
6.62%
Tein S-Tech
166
12.08%
Groundcontrol Coilovers
0.87%
Sprint
22
1.60%
Progressive
88
6.40%
JIC
0.95%
Stock
536
39.01%
Voters: 1374. You may not vote on this poll
What springs are you running on your Max??
After more than 2 years with Maxspeeds, I am looking for something else. The ride is ok, but I would like to be lower and slightly smoother than what I have now. Riders in the back cause the rear of the Maxima to jump up and down over bumps. The Maxspeeds are starting to sag in the rear as well. You get what you pay for.
I like the look of the Tein H techs. Slightly lower than the Maxspeeds and better ride quality than the Tein S techs. It is also a higher quality progressive spring. Should last much longer than the Maxspeeds.
those with h&r and tein h/s weigh in here:
http://forums.maxima.org/showthread.php?p=3696348
Originally Posted by Kevin
hows the ride with them? I'm lookin to do the same setup as well.
Originally Posted by NISMAX03
The ride is fine. The only problem I am having is a little rubbing at the rear due to the G35C stock sized tires (245/45-18). I will be changing the tires to 235/40-18 real soon.
I have the maxspeeds now, and also run the 350z 245/45-18's in the rear and never have had an issue with rubbing. maybe the offset of the wheel that is causing the rub on your car? the 235/40 is a little smaller than stock. the best size to run is the 245/40's if the rim will hold them...you should have an 8in rim for the 245's.
an afterthought...i have not seen anything on b&g springs...they are top of the line like eibach and h&r. every spring co i have spoken to references them, yet i don't know of anyone on the org with them...
http://www.b-gsuspension.com/springs.php
Originally Posted by 2K3MAX2NV
tokico blues and progress springs with 2k5 SE wheels so far no rubbing issues
Do ya have pics of your Max with the 05 rims? Just curious to see how it'd look with that suspension set-up...
Originally Posted by Puppetmaster
Good choice...
nesman, congrats on your first post! welcome to the club! i am sure you will find lots of great info here...don't forget to check out the Group Deal section and the parts for sale section when you are looking for something. contribute as soon as possible so you can use the search function...it is invaluable.
Originally Posted by SoonerMaxima
2002 Nissan Maxima w/ Tein S Tech and Tokico Illumia....not bad...kind of bumpy...want to get better springs
For those who have been running on Tien S and Illuminas for a while...on a 2k...
Can you tell me if the camber is bad and tire wear is uneven? I want this setup but not if its going to result in an uneven tire wear...
Thanks!
Thanks!
Stock springs, stock struts.
The roads here in Louisiana are HORRIBLE. They have ruined my rear springs - especially the right rear spring. I had to put spring blocks in the rear to keep the car from sagging long enough to research what spring/strut package to put on it.
I want to put a package on WITHOUT lowering the car... any ideas?
I have a 2001 maxima gle with 18" giovanna black ararats on 225/40/18 I want to drop it to get that clean look like a 1inch or 1 1/4 what springs would you recommend and would I need to get struts everyone says that u should get struts if ur getting springs but I dont think a 1 - 1 1/4 I would need new struts would I?
I too am interesred in the ride with these Vogtland Springs as I am getting ready to purchase my new suspension and as of right now I am looking at Tokico HP Blues and either Maxspeeds or the Vogtland. I know not many Orger's have these from what I have seen but I am giving it serious thought. Any input is appreciated as usual.
to ME!!!!!
