Speed Limiter Removal
Old Jan 28, 2004 | 04:19 AM
panda_1's Avatar
Anyone Know How To Get Rid Of It?
Old Jan 28, 2004 | 06:17 AM
SkoorbMax's Avatar
I thought that the SE had no electronic governor?
Old Jan 28, 2004 | 06:52 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
apex'i rev speed meter. do a search on google and it should provide answers to the rest of your questions.
Old Jan 28, 2004 | 07:33 AM
jessemcd's Avatar
I think if you get your ECU reprogramed, its toast! The only place that I know of that does 2k-2k1 max's is Jet Performance.
Old Jan 28, 2004 | 07:43 PM
panda_1's Avatar
kk thanx alot guyz
Old Jan 28, 2004 | 11:30 PM
Ghase's Avatar
Oh it has one alright. I stuck the speedo at 120, and my car was stock.!!!!!!!!!
Old Jan 29, 2004 | 03:22 AM
h2kFrosty's Avatar
It should make it to at least 130mph... that's the lowest governor there is assuming you have h-rated tires on your car stock...
Old Jan 29, 2004 | 02:05 PM
Ghase's Avatar
My car never had h-rated tires on. The factory 17' I think come with z-rated tires, and I'am also a cali spec with a auto.!!!!!!!!!!!!!!!!!!!!
Old Jan 29, 2004 | 02:31 PM
sloppymax's Avatar
my 2k1 ae which is cali spec auto will do 128-130 but with speedo error in those digits, there is not telling. i did do 132 in 3rd gear on a dyno pull but that doesnt count since there is no drag.
Old Jan 29, 2004 | 04:13 PM
jessemcd's Avatar
I have a cali spec 5spd and i reached 130, then backed it down cause i was affraid of cops! but it felt like it was still pulling.
Old Mar 16, 2004 | 10:08 PM
panda_1's Avatar
fed spec hits 140 b4 speed cut.
Old Mar 16, 2004 | 10:43 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
cali spec is 130 for the se. the only way is the flashed ecu, but thats only for 2k2/3's...
what do u need to go 140 for anyways
Old Mar 17, 2004 | 12:48 AM
panda_1's Avatar
the occasional top end run.
Old Mar 17, 2004 | 01:58 AM
FanaticMadMax's Avatar
What's the use? Unless you're going autobahn in Germany.
Old Mar 18, 2004 | 07:08 PM
5spd2000max's Avatar
130
Mine pulled only 130MPH @ 6,500rpm's In 4th gear: on Nj Turnpike and I tried to go faster than 130MPH and the gas cuts off
Here is a pic to prove its on bottom of my website at cardomain
http://www.cardomain.com/id/5spd2kmaxima
Old Mar 18, 2004 | 07:15 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
17" 5spd Federal spec SEs had no speed limiter, the AE 5spds didn't have it eighter. I had my ECU re-flashed with the V-rated tires program and it worked fine, then it was reflashed again for yet another MAF, and they put in the OE program- forgot to tell em to do the V rated tire program. Dont matter the Rev/Speed meter from Apexi takes the speed limiter off- I will try to take pics of the speedo pegged sometime with the tach at 6700RPMs.
Old Mar 18, 2004 | 08:49 PM
theMax's Avatar
There is a wire you can cut on your ECU that removes the limiter. This will throw a CEL so put a switch on the wire so you can leave it connected when not in use. Do a search for Ben's ECU mod, as I can't remember what wire this is.
Old Mar 19, 2004 | 05:28 AM
greekmax2k1's Avatar
there is a speed limiter on every maxima....i have gone up to 132 over 20 times and i know...its cuts off it feels like ur car just stops.....
James92SE
142
Jan 2, 2024 09:23 AM
05RLS2
Nov 7, 2016 05:52 PM
Djsmaxima
Sep 14, 2015 11:58 PM
Maxxx10
Sep 13, 2015 03:16 PM
I<3 A32's
Sep 10, 2015 11:07 AM
