Tranny Slippage Tsb
Tranny Slippage Tsb
Hey guys I have that Tranny slippage thing going on. I'm just wondering how much you guys paid to get that TSB done (the solenoid one not the TCM replacement) I know most of you were still under warranty but for those who weren't please stand up. I want to go into the dealer knowing the proper range because I believe the dealer that I live by likes to mark **** up because they are the only Nissan Dealer for like 40 miles.
Moderator, can you delete my other tranny tsb thread. For some reason it didn't post my message.
you could call Dave b and get a quote on the solenoids then maybe look into a local tranny shop doing the install. that would probably be the least expensive route. i had replaced under warranty and of the top of my head i think the soleniods went for 400-500 bucks but i could be way off.
My 2K SE went in to the shop for this repair on Tuesday and it suppose to be ready today assuming the parts do indeed arrive today. I was originally quoted $636.00 for the total repair for just the solenoid valve assembly, but I had a coupon from Nissan that gives me 15% off any geniune Nissan part or accessory so that droped it down to like $540 or so. The solenoid valve assembly part is what makes up the majority of that cost. I 'think' I was told something like $358.00 just for that one part not counting the bolts, gaskets, etc needed for the install.
Originally Posted by scopium
are they covered if i have extended warranty
Originally Posted by miksen
Wait are you guys saying TSB's have to been done under warrenty otherwise you have to pay $$$$ to correct a defective product?
00MAXI,
Man, I am praying for you that you didnt just buy this car.
I am going through this right now in Buena Park, CA. They popped the pan on my car and it was full of metal. I am guessing that this is a result of the previous owner(s) not taking care of the problem right when it started. I had a 50/50 warranty and its going to cost me more loot than I have right now. I am in the process of fighting with the dealership about it right now.
BTW i have 97686 miles, purchased the car on jan 16th with 97296. Brought the car in 6 days after I bought it with like 97480 miles with the problem, and was given the "operating as designed" routine. They said fluid was fine. Now they tell me I must be racing the thing because the fluid is all burnt. These guys are going to get a car driven through their showroom windows and parked on the sales managers desk here real soon.
Dealers that do business like this should be shut down.
I bought the car with 72k on it. As soon as I got it I flushed the tranny, coolant, did the brake pads, switched to synthetic oil, slapped a K&N filter, and had the coils go out at 82k so I replaced those and the plugs. The list goes on but the slipping happened at around 88k. DAVEB is the man he quoted me $281 for the part (my local dealer wanted $364) so sometime next week I'm gonna get that sucka. After I replace the tires hopefully it will be the last big maintenance purchase for a while. FINGERS CROSSED!
Originally Posted by RollinLow
00MAXI,
In my case, the tranny slipping was barely noticeable and only when you got above 4K RPM's. It was more of a delay in the shift between 2nd & 3rd. .
The delay on mine ****es me off especially when I'm heading down to L.A. on that hill that starts in camarillo and ends in Thousand Oaks or agora hills or whatever. When I floor it the rpms race to 4-5k but the car acts like I never downshifted.
I noticed it when I was pulling out into CA traffic. Have to get on it hard sometimes, and I almost got rearended because it wouldn't shift into second. The guy was going like 60. The trans attempted to shift into second at around 5k and slipped up past 6k. I let off because I realized what was happening, and it eventually shifted.
As far as the metal debris, with every transmission I have ever seen with a slipping problem has had grey fluid. Metal particles in the fluid from slipping bands.
I had this issue before as well. 95 firebird formula, 38K on it. When locked into gear lower than D it would act like it was in nuetral under deceleration. It would then have to rev up to the rpm the trans was spinning at to reengage. The fluid was totally grey.
Slightly different problem, still a slip issue, same result. Metal particles and New transmission.
Good point RollinLow. As long as the owner either didn't driver aggressivly enough to encounter this problem or once the issue was discovered it was rectified then the new owner should be fine. My $.02 cents anyway.
Originally Posted by fishhouse
i had mine done a few months ago on my 2k. it was FREE! covered under the 60k mile powertrain warranty.
do you have more than 60k?
Originally Posted by JayMax2000
I have 39,000 with the same problem. But if you have an intake and exhaust done will the warranty still cover it?
I just picked up my car after having the solenoid valve assembly replaced yesterday and it did NOT fix my problem. The next step is to replace the TCM which is a very expensive part. My dealer is calling Nissan to see if they will step up to the plate on this one since they agree with me in that this issue on 2K Maximas should have been a recall, especially since it only applied to very early VIN's which means they changed parts later.
I could be wrong here (wouldn't be the first time), but the tranny slipping issue should not have resulted with metal shavings in your pan. In my case, the tranny slipping was barely noticeable and only when you got above 4K RPM's. It was more of a delay in the shift between 2nd & 3rd. The solenoid valve assembly regulates the pressure which changes the shift points. In my case, the previous owner would have never even have noticed it unless they were drag racing in it. I only knew it because I was aware of the TSB concerning this so I thoroughly tested it out.
It should be a damn recall! The coils should be too! I'm ****ed off!
my car wouldnt reverse or go into 3rd or 4th, i took it to my nissan dealer with intake exhaust and cattman headers and the customer service rep left me a message saying they would replace my whole tranny under warranty since im under 60kmiles, didnt mention a thing on mods, but get this he told me to fill out an evaluation for him which is supposed to go to nissan and asked if i can give him "excellents". I figure since he took care of me ill take care of him
Keep me posted on that.
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
