View Poll Results: Calling all who have opened their 2k2-2k3 HIDs - Any moisture issues?
Nope - Bone dry
61.54%
Yes - Every time I wash or it rains
0%
Yes - Sometimes when I wash it or it rains
15.38%
Yes - At random times I can't explain
23.08%
Voters: 13. You may not vote on this poll
Calling all who have opened their 2k2-2k3 headlights...
Old Feb 3, 2004 | 08:31 PM
housecor's Avatar
How many have experienced issues with condensation/moisture since opening their light? Those who haven't, any special recommendations to assure a solid seal? Or could this be caused by moist air trapped in the headlight?
Old Feb 3, 2004 | 08:59 PM
redstradic's Avatar
no problem whatsoever with my HIDS. didnt use any more sealant than what was already there.
Old Feb 3, 2004 | 09:04 PM
housecor's Avatar
So I assume you heated them back up in the oven to soften the seal and them jammed 'em back together? Did you put them back in for 20 minutes @ 250?
Old Feb 3, 2004 | 09:17 PM
redstradic's Avatar
all i did was just put the black part of the housing back in the oven for 8 min at 250 degress and push them back together. let them sit overnight so the sealant can harden and thats it. personally i dont think there is a need to keep them in the oven for more than 10 min. its not going to make the sealant any more workable.
Old Feb 3, 2004 | 09:19 PM
Ammi's Avatar
350 Detroit Muscle
I just got some waterproof sealant over the existing seal just to make sure no water will get in
Old Feb 3, 2004 | 09:22 PM
Fezzik's Avatar
After I put mine back together (heated them in oven of 200 degrees for 15 mins) i left them in the house for half a day to cool back down slowly instead of being thrown out into cooler weather.
Old Feb 3, 2004 | 09:41 PM
PoLo's Avatar
2-Wheelin it...
the reason there is condensation is because you are prolly sealing it, using your hands, and then pushing as hard as possible. this still leaves enough separation on the top part to have yout hink you're okay, but you're not. i had condensation, i let it dry overnite, then i used plies grips or regular pliers, and just pressed on the edges until it sealed. no one bit of condensation since. 10 to 1 says that's what you're not doing.
Old Feb 3, 2004 | 09:54 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
i did it with a heat gun. heated the glue back up. put it together. When it cooled down, I used a 3/16" bead of silicone around all the headlight. Bone Dry......
Old Feb 4, 2004 | 05:29 AM
NT2SHBBY
I heated mine up-pushed shut and then vice clamped for a few seconds then added a tiny bead of hot glue around edges-i had fog up once-40min after i washed and dried car
I then had car out in rain all day yesterday-drove in it on highway at 80+mph and parked car in garage-no condensation and then this morning pull car out-car was dry and lights were fine
Old Feb 4, 2004 | 06:16 AM
Manaz101's Avatar
After putting them in the oven again, i used a belt and wrapped it in a towel, then i sinched them...used one foot on them while i pulled them. Then left them for about 30 mins, then slapped them on the car and left. That was about 3 weeks ago or so....as of a week ago i've been getting condensation. Only on the drivers side, bad...i'm going to reopen them saturday, air them out and then reseal them....this time i'll use some sealant. hopefully this'll help.
Old Feb 4, 2004 | 06:25 AM
PoLo's Avatar
2-Wheelin it...
did you just use hand pressure or did you use vice grips. is there separation between both pieces of the housing (plastic and rest of housing)...if so, then you just did not tighten them enough. save yourself the trouble of sealant. nothing will top what nissan uses as it's sealant. remove the headlights fromt eh car, let them airdry inside your house (remove bulbs to let condensed air come out) and then use vice grips to close the separation. sealant is gonna look nasty. i didn't have to use sealant and i am/have been w/out condensation.
Old Feb 4, 2004 | 06:28 AM
MannyNJ2k2max's Avatar
Ahh....good technique there buddy...
Old Feb 4, 2004 | 06:29 AM
Manaz101's Avatar
No i didn't use vice grips, don't have any. The strange part is my passenger side is fine, but the drivers side is not. I'm going to redo them saturday.
Old Feb 4, 2004 | 06:40 AM
PoLo's Avatar
2-Wheelin it...
again, save yourself the trouble of opening them up. you WILL be wasting your time because they will prolly get condensation again, and you'll have sealant all over. get vice grips....do it...it LITERALLY takes 5 seconds. you use the pliers to seal the separation between the housings. you'll see them close up more than you've ever tried with your hands....
Old Feb 4, 2004 | 06:45 AM
Manaz101's Avatar
But i'll still have to throw them in the oven right?
Old Feb 4, 2004 | 07:05 AM
PoLo's Avatar
2-Wheelin it...
if you're saying that because you feel the need to soften the sealant, i guess you could do that. i used a hair dryer to open and seal my headlights. remember, you're not opening them all up. you're just softening up the sealant, so no need to heat it up for long. i had it for 2 minutes on a hair dryer and then used the vice grips to close the rest. it was rather simple. and only after i had done that did i realize that i needed to use vice grips cause there was no way i would have gotten it as sealed as it got.
Old Feb 4, 2004 | 07:07 AM
redstradic's Avatar
just go the gym so you can get strong enough to push them back together!
Old Feb 4, 2004 | 07:16 AM
PoLo's Avatar
2-Wheelin it...
Old Feb 4, 2004 | 08:00 AM
looslip's Avatar
Horra!!
You guys are meticulous. I didn't do any of those things you guys mentioned. I just threw it back into the oven for a few minutes, pushed the housing back together and all was well. I guess I got lucky... sorta cuz I kinda melted the area where the balast screws in on my left headlight.
Old Feb 4, 2004 | 08:13 AM
Manaz101's Avatar
I thought i was.... guess i'm not
Old Feb 4, 2004 | 08:54 AM
BLKMAX005SPD's Avatar
all you need is good glue..
I put mine back together and i didn't glue them right...
then it rained and water got inside...
i waited till a nice warm day to get all the water out and reguled them...
i havn't had a problem since...
Old Feb 4, 2004 | 09:50 AM
dblrr900's Avatar
I did mine a long time ago (one of the first ones).
After you put them back on the car, leave out the top little guide light. Leave it out for a week or so, this lets more air in/out of the lights to ballance out the condensation. Put them back in, never had another issue with water.
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
D Mason
Jun 21, 2016 04:43 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
bigfrank
Oct 1, 2015 12:51 PM
