Engine moves to the right... is this normal?
Old Feb 4, 2004 | 10:04 AM
LithiuMax
I went outside to move my car today because of street cleaning, and decided to see if my engine moves when I press the accelerator, switch gears, etc. So I put the car on the hand brake and pressed the accelerator slightly (all done with the hood up, and me peeking between the body of the car and the open hood) and to my surprise, the engine moved to the right and forward. It was more of a sideways motion than a forward one. Is this normal?
Old Feb 4, 2004 | 10:24 AM
SoonerFan's Avatar
Cletus
yes it is....
Old Feb 4, 2004 | 10:44 AM
LithiuMax
Hmm.. well that's good to hear. I keep thinking I have a broken engine mount..
Old Feb 4, 2004 | 10:59 AM
SoonerFan's Avatar
Cletus
the engine mounts have rubber to allow the engine can move.
now if the engine moves alot or you hear clunking, the rubber might be shot (broken mount)
Old Feb 4, 2004 | 11:02 AM
LithiuMax
Clunking when I accelerate, or...? And what's considered to be a lot of engine movement?
Old Feb 4, 2004 | 11:10 AM
SoonerFan's Avatar
Cletus
clunking when the engine has a load (acceleration).
the mount is rubber inside a bracket. there is a hole in it. a bolt connects the engine to the mount. if the rubber is shot, you will hear the bolt clunking against the bracket.
does that make sense? it would easier if i could draw you a picture. o well. hope that helps
Old Feb 4, 2004 | 11:14 AM
LithiuMax
I understand what you are saying.. I don't think I have heard any clunking. Thanks...
Old Feb 4, 2004 | 11:17 AM
SoonerFan's Avatar
Cletus
and i was wrong on what they look like. the one above is how they look on my JEEP.
here is what it looks like on a MAX. same applies, if rubber is shot you will hear clunking
http://www.overnightautoparts.com/ni...tor-mount.html
Old Feb 4, 2004 | 01:47 PM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
when i accelerate my whole car vibrates... like a side to side type thing... (radar dector goes side to side)
could that be a broken motor mount?
is that covered under warrenty?
Old Feb 4, 2004 | 05:09 PM
irish44j's Avatar
retired moderator
open the hood, set the brake (with car running) and then pull the throttle cable (on the throttle body) to rev the car from under the hood...then you can see exactly what it's doing.
Old Feb 4, 2004 | 05:12 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
im pretty sure 2k2 and 2k3 have drive by wire which means electric throttle which menas u cant engage trhottle from under the hood
-J
Old Feb 4, 2004 | 05:17 PM
irish44j's Avatar
retired moderator
yeah that would make sense...forgot about the dbw on the 5.5th gens...
captchaos
Mar 15, 2016 12:18 PM
Vequity
Sep 10, 2015 05:26 AM
AT978
Sep 6, 2015 10:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
