Pads and Rotors for 2k2?
Old Feb 6, 2004 | 12:01 PM
Virus's Avatar
I've called on the group deals and everytime I get, "they don't make a direct replacement for your car". What rotors are available as direct replacement for 2k2's? What pads and rotors are available? I'm looking for blanks, not x-drilled or slotted. I would also prefer ceramic pads if possible.
Old Feb 6, 2004 | 12:03 PM
NT2SHBBY
powerslot makes em-I got all mine from Custom Maxima
hawk makes front pads only but axxis makes rears and fronts
I have all four powerslots with hawk fronts and axxis rears....i will replace my hawks with axxis i think when these wear out
Old Feb 6, 2004 | 12:04 PM
NT2SHBBY
well u can get brembo blanks too
Old Feb 6, 2004 | 02:39 PM
Igor911's Avatar
2k2 rear rotors/pads and IDENTICAL to the 2k-2k1 maximas.
You can use any rear break setup on a 2k2 max from any 5th gen
Old Feb 6, 2004 | 02:59 PM
Virus's Avatar
Every place I've checked with has told me that the 2k2/2k3 Maximas have different size front rotors compared to the 2k/2k1's. Brembo does not make rotors for the 2k2/2k3 fronts. Which Axxis pads? When I called around I was told they had the rear pads but not the front, but I was adament about getting ceramic instead of metal. My main concern with the pads is screeching and squeling like I'm sure most everyone cares about.
Old Feb 6, 2004 | 03:02 PM
Igor911's Avatar
Axxis Metal Masters...
Correct, front rotors are different. Rears are the same
Old Feb 6, 2004 | 03:11 PM
Virus's Avatar
Thanks for clearing that up. How well do the Metal Masters work for both braking and quiet ride?
Old Feb 6, 2004 | 03:12 PM
Virus's Avatar
Another question: I'm having really shaky stopping. In your opinion(s) do you think it's front rotors, rear rotors or both?
Old Feb 6, 2004 | 03:26 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
front rotors...its called brake judder....this means your rotors are probbaly warped
-J
Old Feb 6, 2004 | 04:23 PM
maxS
...not exactly...
dimensionally - on the outside, yes, but if you looked on the inside you would see that 02/03 rotors have less metal there - meaning they are lighter then 00/01. They still are interchangeable though.
Old Feb 6, 2004 | 04:28 PM
maxS
more to it: 02/03 rear calipers have reinforcing brackets:
http://images.cardomain.com/member_i...111_7_full.jpg
regular brakes look like this:
http://images.cardomain.com/member_i...11_14_full.jpg
vsamoylov
and this is where you are wrong. 2k and 2k1 rotors are smaller and heavier and fatter than 2k2. 2k2 rotors got lighter and thiner and bigger so if you try to put 15 inch rims on a 2k2 max on the front, they will fit but rotors and calipers will touch the wall of the rim. but on 2k and 2k1 this is not a problem. I know this cause i wanted to put 2k2 rims on my max and give my old ones to my bro who had the 2k2 on his 2k2 max. and my 15 inch rims did not fit so i had to get the rotors and calipers also.
Old Feb 6, 2004 | 04:30 PM
maxS
he is talking about REARs!
Old Feb 6, 2004 | 04:55 PM
NYC TAR's Avatar
I didn't know the rear ones are vented
Old Feb 6, 2004 | 05:18 PM
GreekMaxima's Avatar
hawk great stoping but noise... axxis are better?
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Socalstillen
Sep 26, 2015 12:01 PM
A32goldylocks
Sep 2, 2015 06:39 AM
