I have a vibration in my steering wheel when I come to a stop.
Old Feb 10, 2004 | 06:16 PM
DallasFan's Avatar
Most of the time it does it when I come to a stop at a light or stop sign. It even does it in neutral. Could this be a sign that a motor mount has gone bad?
Edit. I'm the first one to post a thread since maxorg has been down!
Old Feb 10, 2004 | 06:24 PM
carabuser's Avatar
does it only happen when you're braking? Or idling as well?
If it happens only when you're braking, sounds like your rotors are giving up
Old Feb 10, 2004 | 07:01 PM
fishhouse's Avatar
join the club man...i know several with this problem. mostly 2k owners - who can't seem to track down the cause. myself and several others have just learned to deal with it. mine does it at high speeds or when mid-hard braking.
if during braking, could be rotors. or could be tie-rod ends, wheel bearings, out of balance wheel, bad tire, etc, etc. all of those on mine check out ok...still vibrating though.
perhaps some others will have some suggestions. let me know if you ever track down the cause.
Old Feb 10, 2004 | 08:31 PM
Ammi's Avatar
350 Detroit Muscle
If it only happens when you are braking you might want to turn or replace your rotors
Old Feb 10, 2004 | 11:44 PM
Tony Fernandes's Avatar
I believe there is a TSB for brake judder. Common problem from what I've heard.
Tony
Old Feb 11, 2004 | 04:28 AM
fishhouse's Avatar
the "brake judder TSB" Tony refered to is ONLY for 2000 models. You have a 2003, correct?
yes...as mentioned before that could be the same problem. just be aware that there is no brake judder/rotor TSB on 2k3s. or, might be something else. take it in to the stealership and see what they say.
i had my 2k checked out with this TSB...still no fix. i've given up!
Old Feb 11, 2004 | 05:30 AM
SoonerFan's Avatar
Cletus
warped rotors
Old Feb 11, 2004 | 08:16 AM
MaximaPolak's Avatar
You need some new rotors.
Yours are warped.
Old Feb 11, 2004 | 08:34 AM
SoonerFan's Avatar
Cletus
Yours are warped.
not NEW ones
just resurface (turn) the ones you have
Old Feb 11, 2004 | 11:39 AM
max2kSE's Avatar
couldnt it be that he would need to switch his spark plugs? i mean if its shaking when in idle.....i know a friend who had that happen and when he switch his plugs the shaking went away. *shrugs* just a suggestion.
Old Feb 11, 2004 | 01:16 PM
costcowholesale's Avatar
if the steering still shakes when the car is fully stopped, not moving then its ignition coils problem.
Old Feb 12, 2004 | 10:41 AM
DallasFan's Avatar
It doesn't really shake but it kind of vibrates in my hand for a second and then stops most of the time.
It's not warped rotors because this happens while I am at a complete stop. Switching it to Neutral doesn't seem to make it stop either.
So I guess I'll take it to the dealer and see if it's the coils or plugs.
Thanks guys
Old Feb 12, 2004 | 10:59 AM
SoonerFan's Avatar
Cletus
Thanks guys
might be the motor mounts then
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
