Map light, ignition ring light. . .
Old Feb 12, 2004 | 01:10 PM
futemv's Avatar
I remember that there was a Polarg bulb for the map light in the Max, but I don't remember the part number. I looked around and none of the polarg bulbs look identical to the one I have for the map light. Can somebody please tell me the bulb number and if it produces bright, white light? Is there a better bulb for this?
Also, I tried painting the LED-looking wedge bulb in the ignition ring with a blue sharpie, but it didn't turn out too pretty. Anyone have a link to where I can buy these? I remember seeing them somewhere but can't find em anymore. Thanks
Old Feb 12, 2004 | 04:43 PM
theMax's Avatar
Here is LED replacement bulbs...
Instrument Cluster and Gauge Backlights
http://www.superbrightleds.com/1157.htm
or
http://autolumination.com/74.htm
I bought one from the second link in red. Worked good but could have been brighter.
Old Feb 12, 2004 | 04:58 PM
Spin20's Avatar
what size or model # are the tail lights in a 2000SE? And if any one knows, what is the # to the key ring bulb?
Old Feb 17, 2004 | 06:00 AM
futemv's Avatar
resurrecting this from the dead: which map light from polarg (or any other company) replaces the stock 5th gen map light.
Old Feb 17, 2004 | 06:04 AM
Ammi's Avatar
350 Detroit Muscle
Tail lights are 7443
Old Feb 17, 2004 | 07:45 AM
redstradic's Avatar
map light = polarg m-26
ignition light = bulb 74
everything can be found on ebay for a good price!
Old Feb 17, 2004 | 01:00 PM
Ammi's Avatar
350 Detroit Muscle
except when it comes to shipping. Most people charge $5+ shipping for stinkin tiny bulbs. I've seen up to $8.99 for pair of wedge bulbs. So
Old Feb 17, 2004 | 01:02 PM
DrVolkl's Avatar
I just bought that bulb 74 off of one of the above links...total came to under $5 for 2 bulbs and shipping..
Now, anyone want to tell me how to get that green light outa there?
Old Feb 17, 2004 | 03:44 PM
futemv's Avatar
first, take apart the steering column covers (there are 5 screws to unscrew on the underside of the bottom cover). Then gently pull off the ignition ring assembly. You'll see a longish plastic piece which holds the light bulb. This can be removed from the ring by gently twisting counterclockwise. Then pull the old bulb out of the plastic socket.
Thanks to everyone for the model numbers and links
Old Feb 17, 2004 | 03:53 PM
futemv's Avatar
One more thing: the ignition ring bulb comes in 2 varieties in the second website (http://autolumination.com/74.htm). It comes in LED and incandescent. I know that the Max comes with an incandescent bulb, but can I put an LED bulb in there? Will it be brighter?
Old Feb 17, 2004 | 04:09 PM
ICULookN's Avatar
Kpazzo6 has a good writeup on his cardomain website.
Old Feb 17, 2004 | 05:35 PM
MaxJag's Avatar
Which did you buy?
The incandescent or clear focus lense bulb?
or
Old Feb 18, 2004 | 12:52 PM
MaxJag's Avatar
which one???
Originally Posted by MaxJag
Which did you buy?
Old Feb 27, 2004 | 10:13 AM
theMax's Avatar
Which did you buy?
I got the LED (focus)
Old Feb 27, 2004 | 10:46 AM
DrVolkl's Avatar
Did the focus bulb work? I got the other one...I'm putting it in over lunch today. I'm just happy to get rid of the green. So uncool.
Old Feb 27, 2004 | 02:38 PM
maxirey2000's Avatar
YOu can find the bulbs for the ignition key ring and the map lights at
http://autolumination.com/74.htm.
the part # for the ignition bulb is #74 and for the map lights im not too sure but you can look into it.
Old Feb 27, 2004 | 04:17 PM
DrVolkl's Avatar
Pretty easy to put in...took about 10mins literally. I did break some plastic thing while trying to get at the bulb, but no big deal. Everything is solid again. The inc. bulb isn't very bright, but it is blue...and should look cool at night at least. Who needs it in the daytime anyhow.
Old Feb 27, 2004 | 05:40 PM
MaxJag's Avatar
Please post night shots of each individual bulb so we can get a better
perspective of the illumination. Thanks in advance.
CHEERS!!!
Old Feb 27, 2004 | 08:21 PM
futemv's Avatar
i finally ordered my bulbs. I got a blue one and a super white one. The super white one is brighter but doesn't look that great. The blue one looks really hot especially at night, but isnt that bright. These are incandescent by the way. Pictures to come as soon as I borrow my girl's camera...
Old Feb 28, 2004 | 03:57 AM
custommaximaSE's Avatar
I changed mine but it's not working no more.Does any one knows why?
Old Feb 28, 2004 | 02:12 PM
theMax's Avatar
Check your connections or test the bulb as it may be burned out.
I have the focus and it looks good (not great). It is nice and red but does not light up the entire ring bright. The far side is a little dim.
mvm062
Nov 30, 2020 09:00 AM
minsbang
Sep 11, 2015 08:48 PM
ballerchris510
Sep 10, 2015 09:35 PM
Maxima30
Sep 7, 2015 06:13 PM
JoshG
Sep 5, 2015 10:10 PM
