Bucking at 2,000
Bucking at 2,000
I have a "bucking" problem with my 2K SE 5sp. At about 2,000 rpm in any gear when the engine is cold, it misses, or bucks. I took it to the dealer recently for the 60,000 mi. tune up, and mentioned the problem. They said they would reprogram the ECM. That was about two weeks ago, and the bucking seems worse than before. Also, on two occasions, when I start it , it stalls immediately. It will do this until you gas it after starting.
Any thoughts?
Cricket1
Any thoughts?
Cricket1
I have the same thing happening to my car. When my car is cold, it hesitates and "bucks" violently. It feels like the car is missing IMO. I complained to my dealer about this when my car was under warranty and they couldnt find a problem.
My 2000 Maxima
Hey guys...
I hope i can shine some light on this topic, because I too have had this problem. My 2000 GLE only has 50K. I took it in for the following reason, (i called it hard shifting) from first to second gear, and stalling out at idle. They told me that I had cracked selonids (sp?), my computer needed to be replaced, and I will most likely need a new transmission. He also mentioned that some of these things needed to be check on during the 60K check up because of a default. All of the things were under warranty, but now they are feeding me some bull that the computer is back-ordered for 1 week. I assume this is a serious problem, but won't tell me much...
jp
jp
Yes, but the car still hesitates intermitantly when warm.
I've heard it's normal from other members and it's not coil problem.
Originally Posted by Ben
My 2K se doesn't do that. It doesn't sound normal to me, especially if it doesn't go away completely when it's warm.
Good thing that pulsating is there because it keeps me from gunning my car when engine is still cold Better for the car.
If this problem is normal, I will never buy a Nissan again. I think my car has a coil problem, I just dont really care to change them. I will be getting rid of this POS soon.
Jeez, being a bit rough on Nissan today. First off your (Cricket1's problem) problem is not normal, I had a similar though not drastic fuel cut-off issue that was fixed with a reprogram of the ECU. It is entirely possible that the computer could be toast. I would say take it to another dealer and have a written list of the problems as you experience them, and also check for TSBs relating to anything you are seeing.
And on the Nissan bashing, you have a mass-produced machine consisting of thousands of parts constantly in motion or use. People buy 2 million dollar Ferrari's and stuff breaks on them; it is the nature of machines to fail. The definition of a "perfect" machine is one with no moving parts. My family has bought 12 (one dozen) Nissans in the last 14 years. We have had the occasional problem, but nothing to cause a decision to not buy. Nissans customer satsfiaction ratings speak volumes. It is possible to get a bad car, but lemon laws should prevent this sort of headache. You might want to check with your BBB to find out your rights as a consumer.
I am a pilot and I LOVE Cessna's, but I have had an engine fail once and various small things such as radios crap out and friends have had pistons get holed and oil spray out and the engine totally die. When it comes to machines like that, parts fail and it can kill you, but guess what? I still trust Cessnas with my life. **** breaks, preventative maint. is your life saver. The basic machine is sound and the company understands that a good product brings customers back.
Any thoughts?
Cricket1
Any thoughts?
Cricket1
Thanks to all for the responses! A few other details. The bucking occurs whenever the outside temp is below about 40 degrees, and the engine is cold. Once it the engine warms up, the problem is gone. About 1/3 to 1/2 throttle when cold makes the bucking worst. It does it in 1st- 4th gears at around 2,000rpm. I always only run 93 octane, and just had a new air filter installed at the 60K service. It did not do this last winter at all. Started about 3 months ago. The worst part is the service manager drove it cold, and noticed the problem. He said it isnt throwing any codes, and since it still does it after the re-program, doesnt know what to do. Isn't it their job to find out????
kjlouis
11-24-2018 06:09 AM
6spd4dsc
03-04-2016 05:19 PM
bryants95max
10-02-2015 12:52 PM
