drivers side power window
On my 2000 SE the driver side window is slow to go down and even slower to come up. The window sounds as if it is straining as it is going in either direction. The issue has been around since I bought the car in july. Is this a known problem and is it expensive to repair if so?
before they replaced them, they did lube up the guide which helped but the squealing and sticking came back so thats when they replaced it.
I used carb cleaner to clean the inside of the felt wwindow seals (inside and outside ones) and used white lithium grease on the window track. Problem solved, window goes up and down fast, no problem...I have to do it every couple of months, but no big deal..beats $600.
And it's not a bad window motor.
the track runs on the front and back edge of the window. You don't have to "access" it, just spear/spray some grease in the track with the window down, then roll the window up and down to spread it along the whole track.
Obviously, this may or may not work for you - but it worked for me.....
boomerbrian
Nov 8, 2015 05:10 PM
shaunkey1
Aug 18, 2015 10:09 PM
KGMtech
Aug 18, 2015 09:21 AM
