Rear top hat bolt removal problem
I removed both rear struts. I'm trying to losen the top hat bolt a little. One side I can't even losen it. The other side, I losened it but after compressing the springs, top hat bolt keeps turning w/out coming out. Bolt is turning the strut cylinder. I tried to tighten it back up again but still turns the strut cylinder. I can't losen the bolt and I can't tighten the bolt. Any ideas what I should do?
Someone mentioned you can loosen it a little while it's still inside the car to make it easier to loosen later...
Can someone post a pic of somebody doing this?
I want to see what kind of wrench(es) I need, and how to arrange them... I will be doing my own struts soon as well (for the first time, at least with planned success), and the Tokico Illuminas come with a piece of paper urging you not to use an Impact Wrench.
Originally Posted by KCMichaelM
The the bolt should have a flat where one wrench goes, the other on the nut. And that's a wrench, not a socket.
What's the point of the manufacturers putting torque specifications on the tightening of that nut if you can't even use a torque wrench on it?
So another quick Q, for the front and rears what are the sizes of that nut? (gotta buy some Craftsman box-ends for the job...)
I assume the nuts differ in size, based on the differing diameter of the front vs. rear Tokico Illumina struts' piston rod...
Ammi - Uncompress the spring and turn the top hat bolt a little more. The spring pressure will keep the strut cylinder from spinning. Be sure to only loosen it a little more though - You dont want the spring flying off! Then recompress the spring and you should be able to remove the bolt.
Huttig2009
09-25-2015 03:31 PM
kirkhilles
08-08-2015 10:53 AM
RealityCheck
08-05-2015 06:18 AM
