Cleaning the MAF
Old Feb 23, 2004 | 05:36 AM
Matto357's Avatar
Cleaning the MAF
So, I've read a few times about people cleaning their MAF with throttle body cleaner, how well does this work? How do you go about doing it?
Old Feb 23, 2004 | 06:39 AM
HKMax's Avatar
I'm interested as well.
Old Feb 23, 2004 | 06:51 AM
spirilis's Avatar
I've done it once, although it was somewhat incomplete since I didn't take the MAF out of the tube, only sprayed through the wire grille. I saw a set of security Torx bit sockets at Sears the other day, I might buy that set so I can undo the security torx-head bits and remove the MAF assembly for a much closer/more thorough cleaning.
I noticed a little better overall response. I did do this at the same time as a Throttle Body cleaning, so I can't tell how much of this was due to the MAF cleaning.
As a side note, installing a hyperground kit in my car did result in a mild change in MAF reading according to my OBD-II scantool software. So if you're interested in optimizing things on the MAF sensor, maybe a hyperground kit combined with a MAF cleaning will do you well
Old Feb 23, 2004 | 06:54 AM
MannyNJ2k2max's Avatar
i just used a soft rag to rub out some of the debris
every 3-4 months.....i've had no maf problems
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
