service engine soon
service engine soon
Ok, its happened, I have a 2000 Maxima SE, 5spd, with about 53k miles, and the service engine soon light came on last night. Its not going away. Is there any way I can check to see what is going on without buying a $6000 tester?
Thanks,
JimL
00 Maxima SE, 5spd (3%)
Thanks,
JimL
Thanks,
JimL
Thanks,
JimL
tester
Originally Posted by sloppymax
take it to autozone, its free. by the way, testers can run about 100-200 bucks. i went with some software that i loaded on my old laptop for about 120 or so.
Really,they will diag it for me, how do I get in on that one? Just bring it in and ask teh to check it for me?
Thanks,
JimL
Thanks,
JimL
Thanks,
JimL
Thanks,
JimL
Thanks,
JimL
I also have a 2000 Maxima SE 5spd , with about 53K miles. The service engine light came on last night.
Is something like this still covered under warranty (5yr/60k) ?
Share your results when you get them.
Cheever
Check Engine Light
I just had the same problem on my 2001 Maxima
I took it to Nissan and there was a TSB on it. Nissan fixed for free. Unfortunately I previously paid a diagnostic fee to my mechanic thinking something major was wrong.
Here's the notes from the documentation from Nissan:
A C/S Check Engine Light is on
Cause: F
DE98AA Reprogram Engine Control Unit
19 Warn
FC: HD32
Part#: 237105Y006
Claim Type: PP
60217 Found Old Ecm Program Warr - 23710-5Y006 Checked EFI system for P0420 and reprogrammed ECM per NTB00-070a
I believe store code in the ECM is:
DTC P0420
Hope this helps but for sure get the code for free if possible.
P.S. The technician said that this particular problem is covered up to 80,000miles.
Cause: F
19 Warn
FC: HD32
Part#: 237105Y006
Claim Type: PP
DTC P0420
service engine soon
[QUOTE=kevinsean23]I just had the same problem on my 2001 Maxima
<snip>
Well that helps, I usually do my services at the local Nissan dealer cause they are pretty fair, honest, resonable. I will check it out with them. Lanks for the info, I will post later with the results.
Thanks,
JimL
<snip>
Thanks,
JimL
O2 sensors
Turns out I had two bad oxygen sensors. Should have gone to Autozone, could have saved $100.
Originally Posted by ajahearn
Had the same thing happen to me yesterday. Fortunately still under warranty. Nissan dealer showed $300+ for the work. These increasingly occurring failures are really starting to make me worry.
I took my car to the dealer today for the SES light. Well as I should have expected, it turned out to be a bad O2 sensor.
The price for the fix was $290, which at the time, I thought was a ripoff. I guess I was wrong.
Thank you Nissan for putting in horrible O2 sensors.
Cheever
Cheever
Cheever
shilov
Feb 19, 2024 09:40 PM
