Headlight not working!!! right front low beam only on 2000 Max
Old Feb 26, 2004 | 04:39 PM
CraigSE's Avatar
Need help here.
everyone has been helpful to me in the past.. so hopefully someone could shed some light.
first of all, for some reason I was unable to search, it said i didn't have permission (whatever, i don't know why)
Anyhow... the low beam on my right front headlight on my 2000 Maxima is completely dead.. it just stopped working one night.
so I thought no big deal, pop in a new bulb.. no difference.
to make a long story short... 5 bulbs later, swapping the relays later, swapping fuses with new and used, cleaning the grounds, checking all the connections, the low beam STILL DOES NOT WORK... the daytime running lights come on (both sides) no problem, and the highbeams work whether you flick them, or activate them so they are turned ON. but the low beam refuses to come on no matter what I do.... keep in mind, the drivers side low beam has been working fine this entire time.. as well as the foglights. NO other bulbs in the entire car are burnt out either.
Has anyone ever run into this? the only thing I have not been able to swap was the DRL module (which the headlights run through)
someone help... honestly, i have no clue what the hell to replace.
Thanks.
Old May 17, 2004 | 11:48 AM
davidveinot's Avatar
I have the exact same problem. I've been told that I need to replace the DRL module. Does this fix the problem? Waat else can I do? HELP!
Old May 17, 2004 | 11:52 AM
Igor911's Avatar
Thats weird! Take it to Nissan...something like that is def. under wntty.
jerrod99_se-l
Aug 27, 2015 08:27 PM
Samedi
Aug 12, 2015 01:54 AM
jholley
Aug 11, 2015 09:38 AM
MikesChevelle
Aug 10, 2015 11:21 AM
kenc15
Aug 5, 2015 08:29 AM
