Best paper ail filter?
Old May 16, 2004 | 01:23 PM
trey
I don't have an intake and was wondering what you guys think is the best paper air filter for my 03? I'm not considering a K&n.
How good is the oem one?
Old May 16, 2004 | 02:56 PM
Pir8 97's Avatar
What's wrong with K&N. You like changing your filter all the time? You don't want the better gas mileage & hp that comes with the K&N? Too expensive? Trust me, its worth it in the long run. I had a K&N stock replacement in my last two cars and never had any problems.
Old May 16, 2004 | 03:00 PM
trey
Well, I'm just not a k&n fan. i mean if your letting more air in then your letting more dirt in right?
Also, even if i do gain 1-2 horsepower, are you really going to feel it? Then I might gain a tad more mpg, big deal. I mean 10-15 bucks for a paper filter that filters better i think is worth it.
If i was racing I might consider a k&n but for normal street use nah,
jus my 2 cents, flame on.
Old May 16, 2004 | 03:14 PM
Pir8 97's Avatar
Nothing to flame... I'm just offering my insight from past experience. Since the filters are oiled they actually trap more dirt than standard filters. You will gain more than 1-2 hp... not enough to go drag racing but you should notice a better throttle response. I think I gained like 4 mpg with the drop-in, which on an 18.5 tank is another 74 miles... nothing to scoff at with gas prices these days.
Old May 16, 2004 | 03:24 PM
NYC TAR's Avatar
Nissan OEM is best paper air filter for our car and the filter is about 10 bucks. I know it filter out very good since I see alot of dirt after 10K of normal driving.
Old May 16, 2004 | 03:52 PM
trey
Even with the oil, if its letting more air in that means more dirt, at least thats the info i'm getting from bobistheoilguy.com web site.
Old May 16, 2004 | 05:50 PM
aussie983's Avatar
yep. K&N still let in more dirt due to the wet/oil filter type. There was an experiment where they simulated various fiter types, on the end of a vacuum cleaner and they put in a sheet of clean white material downstream, to see how much dirt the filter didnt trap. K&N was one of the better performers, however it still let in a good amount of dirt.
Old May 17, 2004 | 08:16 AM
Virus's Avatar
You will absolutely not gain more than 1-2hp with a K&N drop in and it's ludicrous to think a K&N filter will stop more dirt than a paper filter would. K&N filters let quite a bit of dirt in. If you go to their website you will see that their standardized test is a different number than the others use. That's because the test they use allows for bigger particle sizes.
To answer your question the Nissan OEM filter is the best paper filter available.
Old May 17, 2004 | 08:48 AM
ABS's Avatar
ABS
I'm completely with you on this one. Good filtration is the key to long engine life. Use a K&N and just count the miles until you're burning oil from all that dirt getting in . . .
Old May 17, 2004 | 08:52 AM
NCTRNL's Avatar
K&N filters and other oiled filters can cause a lot of issues with your MAF because of the oil.
Old May 17, 2004 | 12:31 PM
trey
thanks guys, nissan oem for me. I think courtesyparts.com has em pretty cheap from what i remember
my03maxima
Jul 28, 2024 07:40 AM
Justin Kroll
Oct 1, 2015 07:03 PM
Redfox
Sep 28, 2015 10:41 AM
bumpypickle
Sep 20, 2015 08:22 AM
