YPIPE install problem PLEASE HELP
Old Feb 27, 2004 | 11:50 PM
scopium
i installed my warpspeed y pipe today..
everything went well...
but when i floor it ...it sounds nasty.. f feel ratteling from the y pipe..its like something is vibrating...
only when i floor it though.. crusing no sound
any ideas.. please help me .. that thing sounds nasty
from the inside of the car .. it feels like its coming from right under the shift booth.. and i have an auto
Old Feb 28, 2004 | 12:29 AM
2kGLE's Avatar
probably the heat shield. this is a pretty common problem. I just bent mine so it wouldnt vibrate like that.
Old Feb 28, 2004 | 04:15 AM
redstradic's Avatar
you have to use about 6-7 washers on the bolts to bring the y-pipe down so it doesnt vibrate or bang against the cross member.
Old Feb 28, 2004 | 07:14 AM
scopium
are u talking bout the heat shield that is attached to the precat or the one that is right on top of the y pipe?
Old Feb 28, 2004 | 08:09 AM
MaxSE03's Avatar
No, he is talking about the cross member / brace that is below where the main cat and cat back are bolted together. Drop the brace and add some washers or just remove it, and the noise and vibration will go away. This is a very common problem with the Warpspeed pipe.
Old Feb 28, 2004 | 09:01 AM
scopium
so that should be the only problem? cause all the bolts are tight so i'm pretty sure there is no exaust leak
Old Feb 28, 2004 | 09:29 AM
chinaonnitrous1's Avatar
get under the car, shake the **** outta yer exhaust and keep an eye out for where it might bang into the heatshield. Or have a buddy turn the car on while your underneat, and rev it up. Ha ha ha Just KIDDING
Old Feb 28, 2004 | 05:06 PM
scopium
OK guys.. i took out the brace and everything is fine now.. no more ratteling
question.. is the brace necessary for anything... is it anything crucial... for handeling or safety...
thanks for the help guys..
5th gen for life (until my car brakes down)
Old Feb 28, 2004 | 05:23 PM
MaxZ71's Avatar
all i know is my brace has been off my car for about 9 months and still no problems
Old Feb 28, 2004 | 08:26 PM
Virus's Avatar
You have 2 choices to get rid of the problem. Put 6-7 washers and extend the brace down or do what most of us did and take the brace off. It will totally solve your problem.
Old Feb 29, 2004 | 04:02 AM
ssheltz's Avatar
Nissan wouldn't spend the extra $$ to put the brace there if it did nothing.
I would put the washers in place and drop it ~ 1/2 inch. I have 7 washers on mine and it did the trick.
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
vingodine
45
May 21, 2016 12:46 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
kirkhilles
Aug 8, 2015 10:53 AM
