So i got bored this weekend and decided to change the leds in my switches...
Old Feb 28, 2004 | 05:52 PM
blueeyce's Avatar
Pulled up the How-To by Alex Hsu and it looked simple enough. Thanks for the write-up btw. But i didn't want my PS window switch a different color than the PS lock switch. So i figured i'd take a shot at the window switch. Not too hard, just have to be careful and a little patient. So what do you guys think?
Driver's side
Passenger side
Old Feb 28, 2004 | 06:03 PM
MyownNismo's Avatar
Future Camaro SS owner
Driver's side
Passenger side
Pics not working.
Old Feb 28, 2004 | 06:17 PM
blueeyce's Avatar
How about now?
Old Feb 28, 2004 | 06:20 PM
s_hinerman's Avatar
yep working now! Looks nice!!
BioMaxDDS's Avatar
where is the writeup?
looks nice
Old Feb 28, 2004 | 06:21 PM
2k3TitaniumSe's Avatar
Looks nice...reminds me of my cousin's Jetta 1.8T
Old Feb 28, 2004 | 06:23 PM
blueeyce's Avatar
looks nice
Sorry i didn't take pics during the process so without pics it'd be pretty hard to explain. But if someone in the area is interested i can show them how and i'll do a writeup then. Anyone interested?
Old Feb 28, 2004 | 06:30 PM
PearlWhtMaX2000's Avatar
where did u get the write up?
Old Feb 28, 2004 | 06:33 PM
blueeyce's Avatar
http://www.max-world.org/frames/howtodo.html
look under electrical
Old Feb 28, 2004 | 06:46 PM
2002 Maxima SE's Avatar
nope...no pics
Old Feb 28, 2004 | 07:14 PM
blueeyce's Avatar
Originally Posted by 2002 Maxima SE
nope...no pics
they're working for some people
Old Feb 28, 2004 | 07:29 PM
I pasted the direct link...nothing there:
http://68.193.158.145:1024/images/te.../ds_switch.jpg
http://68.193.158.145:1024/images/te.../ps_switch.jpg
Old Feb 28, 2004 | 07:49 PM
blueeyce's Avatar
www.erickoelle.com/pages/maxima.htm
^does this work for you?^
Old Feb 28, 2004 | 08:59 PM
ICULookN's Avatar
Looks real nice.
Old Mar 1, 2004 | 04:48 AM
blueeyce's Avatar
bump for the monday morning crew
Old Mar 1, 2004 | 05:03 AM
SoonerFan's Avatar
Cletus
Driver's side
Passenger side
how did you do the passenger window switch?? i tried to do mine and had springs and ball bearing everywhere. AND the bulb is diffirent. now i have a broken switch that is still green!!!
Old Mar 1, 2004 | 05:34 AM
blueeyce's Avatar
I removed the existing bulb and that green rubber holder. then i soldered the new led in between the two copper contacts. only difference is you have to use a 3Kohm resistor on the the positve side of the led. as far as the rest of the switch i just made sure i put it all back together the way it was. Do you still have the parts that came out of the switch? If you do you can send it to me and i'll fix it for you.
Old Mar 1, 2004 | 05:40 AM
SoonerFan's Avatar
Cletus
i have all the pieces but i couldnt get it to work. i tried to put it back together but didnt really know how since all the pieces fell out, i dont know how they go
Old Mar 1, 2004 | 05:42 AM
Working again!
Old Mar 1, 2004 | 05:59 AM
blueeyce's Avatar
Here's a crude diagram for you.
the ball bearings sit on top of the metal contacts and the plastic cover has the 2 small springs that should sit on top of the ball bearings.
Old Mar 1, 2004 | 08:11 AM
thomasd cook's Avatar
Are the LED's a direct swap with resistors built into the board or do you have to solder the resistors on also? I've got some LED's to try this with. I'm going to attempt one tonight.
Old Mar 1, 2004 | 08:42 AM
blueeyce's Avatar
They are not a direct swap. You have to solder the new LED in place, but first you have to solder the resister to the LED and then to the contact on the switch. Be sure to pay attention to where you place the resistor in reference to the sliding mechanism and the top half of the switch. You'll see what i mean once you open it up. Also, there is no circuit board. Just two copper contacts. Again, you'll see what i mean once you open it up.
Old Mar 1, 2004 | 09:12 AM
If I do this it would probably use super white or red LEDs. If white it would be a perfect match to the rest of the car. Or I can give it a euro look and make it all red. Even the guages.
MaxLife17
Jun 27, 2019 01:37 PM
The Wizard
24
Oct 1, 2015 08:47 PM
thenewguyy
Sep 12, 2015 11:12 AM
minsbang
Sep 11, 2015 08:48 PM
MaxLife17
Sep 8, 2015 02:36 PM
