P0420 and reprogrammed ECU but no help!! Now need a $1000 Catalytic Converter! HELP!
Old Mar 2, 2004 | 07:40 PM
Komax's Avatar
Since the 80/80 warranty doesn't cover the catalytic converter, I have to get a new one. Dealer quoted me $1000 for a new catalytic converter. NO WAY. What other alternatives do I have? How is Random Technology? I know it is cheap but will it be clean and pass emmissions?
Who has the Random Technology catalytic installed?
Old Mar 2, 2004 | 08:04 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i have seen some people post about the flash of the ecu not helping as well but then their dealer replaced the cat and all was good. this was done under the federal emission warranty of the 8yr./80k.
i do not have any personal experence with rt cats but every post i see about is negative. they fall apart and fail within a year or two. again, i dont have one so i cannot say for sure. my advice would be to contact NNA. i was under the impression that the main cat was covered under the federal warranty. 1-800-NISSAN1
Old Mar 2, 2004 | 08:11 PM
5 spd's Avatar
http://forums.maxima.org/showthread.php?t=290532
I dont see why the 2k2 exhaust wouldn't fit on your 2k.
Old Mar 2, 2004 | 08:15 PM
PhxBlue's Avatar
MK3 Supra and Focus ST
I have had my rt cat about 10 months w/o probs, havent had to go thru emissions yet tho.
Old Mar 3, 2004 | 04:35 AM
sloppymax's Avatar
the problem is that this link is for a catback which would essentially be the piping from behind the cat (b pipe). you search car-parts.com for a cat in your local area salvage yards if you want nissan and do not want to fork out for new.
Old Mar 3, 2004 | 04:59 AM
naerok's Avatar
Mine was covered under warranty.. try another dealer...
i tried several b4 they stated it's covered under warranty...
Old Mar 3, 2004 | 05:28 AM
das's Avatar
das
I had the same code and got my cat replaced free under warranty too! Your dealer is tryin to rip you off. Its covered under 80/80~~
das
Old Mar 3, 2004 | 06:41 AM
Komax's Avatar
das
But I have 88,000 miles on my car.
Old Mar 3, 2004 | 09:33 AM
xfirepwr1's Avatar
Salvage yard will not sell you a catalic converete its is illegal.
Old Mar 3, 2004 | 09:37 AM
xfirepwr1's Avatar
If you need a Random cat I can sell you mine. I bought it last year and never had time to put it on its brand new in the box.
Old Mar 3, 2004 | 02:54 PM
sloppymax's Avatar
that i did not know. the closest yard to me must not care because they offered quite a few at real good prices and did not say about coming after hours. oh well.
Old Mar 4, 2004 | 10:34 PM
cyclecrazy55's Avatar
cat converter advice
As much as Nissan would like to convice you that the catalytic converter is not covered under the 8yr/80k warranty, it absolutely is. I had the exact problem. My P0420 code came up at around 72k. Had the ECU flash with no result. I did my own code pull with the OBD 2 and found the cat to be the problem. Nissan said it was only covered under the 5y/50k. My warrany book said 8k/80 under FED or CALI emissions. 1800Nissan1 played the same song and dance. How I finally got satisfaction is that I wrote a letter to the california/Fed EPA and gave them copies of the work and names that I talked to at Nissan1. 4 weeks later , surprise!! I got a call from Nissan1 saying they were mistaken and the cat is covered under 8yr/80k. Now I have a new catalytic converter and had the ECU flash reimursed to boot. Gotta love the EPA!! Make sure you don't have any aftermaket intake. The dealer tried to pull "the cat failure is from the intake" excuse. Good luck. If all else fails I hear the radom cat fixes the problem. But you have to drive the car a bit to warm it up before it passes inspection.
Old Mar 14, 2004 | 06:57 PM
Komax's Avatar
Wow, thanks for all your help.
Anyhow, I replaced the stock cat with Random Tech and guess what!!! NO CEL LIGHT! I was right. I'm always right. Got 4-5 more hp and car is running awesome. I hate the P0420 code. There was a reason why they changed the cat in the original TSB. Punks.
Old Mar 14, 2004 | 08:37 PM
NYCe MaXiMa's Avatar
this sucks.. i have over 100k miles what to do..
Old Mar 14, 2004 | 08:51 PM
Komax's Avatar
what the heck are you asking?
Old Mar 14, 2004 | 09:19 PM
I'm asking what I can do to make the P0420 code go away... seems like the 'only' sure solution is to take it to the dealer and get the cat converter replaced under the 80/80 warranty.. but I'm over 100k miles thus it doesn't apply to me.
And there is no way in hell that I would pay like a grand for a new Cat from the dealer.
Old Mar 15, 2004 | 03:45 AM
Totalpckge1's Avatar
Son listen. I just got the same code last week. I also have a 2000 Max. As it turns out all the dealer needed to to do was update the software in the ecu. So they reprogramed the ecu for $85. Problem solved.
Old Mar 15, 2004 | 08:00 AM
Komax's Avatar
There are 2 reasons why P0420 comes out. TRUST ME. This happened to me.
1. Totalpckge is right. First is the problem of a reprogramming that needs to be done. It does cost between $80-100 and takes about 1 hour.
2. HOWEVER, there is another reason for P0420 to come out. The catalytic converter has gone bad. I had the dealer look at my car twice before I realized that the cat went bad. They "reprogrammed" twice before they wised up to actually testing the cat. The cat failed and needed to be replaced.
I was quoted $950 for the new cat and install. I laughed in their face and said, "See Ya!!!". I check online and found Random Tech. THis is warrantied for 3 years and got decent reviews. I ordered it and it immediately corrected everything. It passes EPA (which is important for all you "cool" people going for test pipes and straight pipes) and won't kill my infant son and other people. BTW, straight pipes only give less than 3 hp.
I paid for the install for $40 at a local shop. Total cost $240 including install, shipment and cat.
I'm always right.
Old Mar 15, 2004 | 09:42 AM
sloppymax's Avatar
I'm always right.
do you have a dyno showing your 5hp gain or is that mental hp?
Old Mar 15, 2004 | 03:11 PM
Komax's Avatar
how much is a dyno? i need to do that. i bet mine will say 549hp at 5500rpm.
Old Mar 15, 2004 | 03:38 PM
sloppymax's Avatar
i could not tell you what you locally but around me it varies from 50-60 with a/f for 3 pulls.
Old Mar 20, 2004 | 03:26 PM
jnovember's Avatar
You did much better than I did. Mine came on with this code at 58k. Reflash of ECU only worked for a short while. Drove the car with the light on, then off, then on, then off...... until 78k. Was told 'pre-cat' had to be replaced for $1,000. I argued with dealer and 1800NISSAN1 that warranty book said converters were covered for 8/80. They both insisted, not the "pre-cat", but Nissan paid for 50% of the repair. Now at 95.6k and light has not come back on.
gigabyte
Jan 6, 2017 06:05 PM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
