is this safe to do?
Old Mar 6, 2004 | 01:40 AM
panda_1's Avatar
is this safe to do?
item number 2464613550 www.ebay.com
Old Mar 6, 2004 | 04:48 AM
Tony Fernandes's Avatar
No. Our wiring supports 55/60W bulbs. Not to mention the fact that they are yellow, and headlights need to be white. Assuming they were the correct wattage, yellow would be okay for your fog lights.
Tony
Old Mar 6, 2004 | 10:56 AM
2k3TitaniumSe's Avatar
Don't get them. They melt your harnesses.
Old Mar 6, 2004 | 05:50 PM
panda_1's Avatar
what is i upgrade the harness would the housing hold the high temp?
Old Mar 6, 2004 | 09:43 PM
† ErV †
technically. if you connect higher gauge wires to the terminals, via a direct battery feed controlled through relays from the stock wiring, you should be able to run whatever your electrical system can dish out. it is a DIY project. pretty simple but tedios.
and last time i played with the H4 socket i broke a piece of the plastic. it's pretty crappy since the wires are short and you have limited room to work with.
Old Mar 6, 2004 | 10:57 PM
I've heard the hotter bulb will eventually melt the housing. Anyone else?
Tony
MaxStock
Dec 5, 2016 05:19 PM
sliptap
Sep 30, 2015 05:57 AM
Andy29
Sep 29, 2015 05:32 AM
bumpypickle
Sep 20, 2015 08:22 AM
